Introduction: 5V - 2A Regulator
This is a regulator circuit using LM78S05 IC. it is a 5v regulator IC with 2A current output . this circuit is very useful for those who need more current output . this is an easy circuit and consists of very few components.
Step 1: Parts List
1. 1 x LM78S05 IC
2. 1 x 220uf
3. 1 x 47uf
4. 1 x 1N5400
5. 1 x dot matrix board
Step 2: Circuit Diagram
Complete the circuit according to the circuit diagram and solder them according to the circuit diagram. use a heat sink for the IC use a large heatsink than the heatsink shown in picture since the heat was too high when I used this heatsink
Step 3: Conclusion
hope this circuit gets useful to you guys... give me feedbacks and rate this instructable anplease rate this instructable....
25 Comments
4 years ago on Step 1
How many volts of the capacitor
Reply 3 years ago
220uf/50v and 47uf/25v
7 years ago on Introduction
This circuit will work perfectly in 99.9% of use cases. And will fail with the most unpredictable effects in the rest. Put two 100nF ceramic capacitors between input and ground resp. ground and output. Put them as close as possible to the IC.
As I said, otherwise the thing will work very nicely MOST of the time. With MOST of loads. And it may start oscillating and producing any kind of output voltage in other cases (lower than 5V, higher than 5V, about 5V with a lot of high frequency on top, it may change when you tap it with an oscilloscope probe...).
Add the two ceramics (100nF to 330nF) and you'll be fine.
Reply 7 years ago
cud u plz tell where to add the 330 nf capacitor ?
Reply 7 years ago
One from pin 1 to pin 2 (in to com) and one from pin 2 to pin 3 (com to out). As close as possible to the IC!
Reply 7 years ago
and the current supplied will be equal to current output ???
Reply 7 years ago
Yes. The input current is equal to the output current (plus the very small current the regulator needs for itself - but that is only µA to mA)
Reply 7 years ago
i need to amplify the current output of a solar panel cud u plz help me ?
the output from it is 24 V and 0.1 A i need to increase the current up to 1A
Reply 7 years ago
Put ten of those panels in parallel. Or use a switching power regulator. But to get ten times the current, you can only get a tenth of the voltage (1A @ 2.4V). And as nothing is perfect, there will be losses in the regulator.
Reply 3 years ago
sir regarding to 24v and 0.1 A from Muhammand BilaIA, do you mean he should put 10pcs of 100 nf ceramic capacitors of those panels?
Reply 3 years ago
how many hours could i charge my battery if i use this, just in case?
Question 4 years ago on Introduction
This is dc-dc. Can is do it ac-dc regulated power supply?
5 years ago
i am made smart pawerbank 5v 2m
5 years ago
sir send me this vedio my watsup no......7210537221 ..... 5v 2m ...i hope you send .
5 years ago
sir what can i use as an alternative for LM78S05? Thanks hope you reply
6 years ago
Sir,
Can i use IC7805 here?
Reply 5 years ago
yes but u il get only 5V 1A output
5 years ago
Okay so I have a Aukey 5v 21Watt solar panel.
Problem-
Under full load the output voltage drops significantly, even while under full sun.
Solution-
Figure out how to regulate the voltage to within .1 volts.
I need to be able to boost 3-4v to 5v while also being able to pass through 5v when it's able to do so.
the panel has two 5v 2a USB 2.0 outputs.
suggestions?
Reply 5 years ago
this circuit works only with minimum 9V input and it cannot be used for boosing 3-4 v to 5V
5 years ago
can i use to regulate current from two 18650 batteries to 5 v ?
