Introduction: 6" Open Face Jewelry Display Box
What you’ll need:
Scissors and/or an X-ACTO knife
6" open face jewelry display box accent piece template
Paintbrush
Small bowl
Rose gold metallic paint
6" open face jewelry display box template
12” by 12” card stock
Glue and/or double sided tape
A pencil
12” by 12” printed acetate paper
Ruler
Pin(s) or a pen
Step 1: Print the Accent Piece Template
You can download the template here.
Step 2: Paint Over the Accent Pieces With Rose Gold Metallic Paint
Set aside and let dry.
Tip: Apply two coats of paint to get the greatest colour payoff.
Step 3: Cut a 3" by 3" Square Out of the Printed Acetate Paper
Set aside.
Step 4: Print the Box Template
Step 5: Cut the Template Out With Scissors or an X-ACTO Knife
Step 6: Trace the Template Onto the Card Stock
Tip: Use some of the other project supplies to hold down the template while you trace.
Step 7: Cut the Card Stock Out With an X-ACTO Knife or Scissors
Cut along the broken lines as well.
Step 8: Fold the Card Stock Along the Solid Lines
Tip: A ruler provides a hard edge to fold the card stock over.
Step 9: Cut the Accent Pieces Out With Scissors or an X-ACTO Knife
Set aside.
Note: In the photo there are a few different accent pieces because at the time I wanted to have different options to play around with. The pdf. attached to this project however, only includes the accent pieces I ended up using for this project.
Step 10: Adhere the 3" by 3" Piece of Acetate Paper to the Bottom of the Inside of the Box With Double Sided Tape or Glue
Note: You may need to reduce the acetate paper to 2.8” by 2.8” to ensure the box flaps are able to fold over and lay flat.
Step 11: Fold One of the 3" by 0.25" Rectangular Accent Pieces in Half and Adhere It to the Edge of the Flap at the Front of the Box
Tip: Use a ruler to help fold the rectangular accent piece in half.
Note: I included three additional 3" by 0.25" rectangular accent pieces in the accent template pdf. just in case you want or need extras.
Step 12: Adhere the Large Rectangular Accent Piece to the Inside of the Box With Glue
Ensure all the pieces are securely glued or taped to the card stock.
Step 13: Apply Glue or Double Sided Tape to the 1st, 2nd and 4th Flaps
Adhere the 1st and 2nd flaps to the inside of the 3rd flap; then fold the 4th flap inward over the 1st, 2nd and 3rd flaps.
Repeat on the opposite side.
*Refer to the above image or to the Open Face Jewelry Display Box Template pdf. for the respective 1st, 2nd, 3rd and 4th flaps.
Step 14: Poke Holes Into the Hole Markers With a Pin/Pins or a Pen
Step 15: You’re Done!
Now you can arrange your rings, earrings and bracelets in your rose gold accented jewelry display box.
Note: If you have heavy jewelry you can reinforce the bottom and/or back of the display with cardboard or heavy card stock.
Enjoy!
