Introduction: 6 Wheeled Rc Truck Tank
If you like to build this is where you should be.
Step 1: The Parts: 1 Rc Truck , 1 Rc Truck Axel , Some Sort of Connector Piece, Optional Tank Treads
Hello, I'm new to this. I've build projects before except never post them online before here's one of them.
Step 2: Put It All Together
Take the truck and where the wires are go to the back wheels. Very carefully about halfway down the wire. (Keep the wire connected but very) carefully strip a little bit of the wire. Take the wires from your back wheel axle and there are two options here you can either solder the wires together or wrap the wires around each other and then put electrical tape on them make sure you get the battery connections right. You might want to try it the back wheel first and on a 9 volt a battery to see which way you're supposed to put the wires.
Step 3: Making the Connector
There's not much more I can tell you how to make the connector. As long as it is strong it will work.
Step 4: Tank Trends
You can use anything for the tank treads.
