Introduction: 6v Regulator
This is a circuit used to convert a voltage range of 7.5-16v to 6v 1A output this circuit consist of 7806 regulator IC and few capacitors the circuit is simple and easy to make and can be used as a bread board powersupply and for charging 6v batteries and lots of other purposes
Step 1: Parts
1 1 x 7806 IC
2 2 x 470 uf (electrolytic capacitor)
3 1 x small piece of common circuit board
Step 2: Circuit Diagram
make the ciruit according to the circuit diagram provided and use an aluminium plate as a heatsink to the IC or else the IC will get overheated and damaged
Step 3: Conclusion
use this circuit according to the purpose you need and dont forget to add the heatsink.. to IC
