Introduction: 7 Alternative Uses for Balloons
In this Instructables, we look into seven ways to use balloons.
Let's dive in!
Step 1: Drinking Glass Identifier
If you like to party, most likely you know the situation: Eh, which is my glass?
With so many glasses on the table, it's easy to loose your drink.
Since you're in the party, it's a good chance you'll find a balloon.
Use the balloon to cover the bottom of the glass.
Now you can easily identify your glass.
Step 2: Pimp Your Mouse
Balloons are great to pimp your mouse.
You can make it more colourful to suit your personality or match the computer.
It will also have a better grip.
- Take off the top of your mouse.
- Cover it with a balloon of your choice.
- Put back the top and enjoy your colourful mouse.
Step 3: Yarn or String Lampshade
Balloons are great for moulds.
You can use a big balloon as a mould for a string/yarn lampshade.
I used a very big balloon as it seemed to be more round when inflated.
I used yarn and wallpaper paste to glue it together.
I have also made yarn lampshades with white glue, but I prefer wallpaper paste as it's cheaper (at least where I live) and it's easier to clean it up.
Wallpaper paste might take longer to dry than a white glue.
Prepare your glue and pour some in a jug.
Feed in some yarn and push it down, so it gets covered with the glue.
Keep topping up the glue as well as feeding and pushing down the yarn.
When you reach the end, feed it through the spout and cut off the dry yarn.
Step 4: Yarn or String Lampshade
Now cover the balloon with the yarn.
It's very easy to do it this way.
You can spin the balloon or wind the yarn by hand.
When you reach the end, tuck it under other layers of yarn.
Hang the balloon to dry.
It will drip, so put a bucket under.
Drying time will depend on various factors.
Estimated drying time: 36h - 96h
Usually the bottom will dry last, so the ball might seem hard, but the bottom will be soft.
Step 5: Yarn or String Lampshade
When the ball is dry, pop the balloon and cut a bigger hole to remove it.
There are various ways to hang the lampshade.
I made a hook that attaches to the cable and holds the lampshade.
Step 6: Brighten Up That Chair
If you have a chair that needs to be brighten up, balloons are great for that.
Put a balloon on a permanent marker or a similar item that size.
Roll it down.
Now roll the balloon on your chair's leg.
Repeat the procedure for all the legs.
Put adhesive pads on the bottom, so balloons would not break.
Your rainbow colour chair is ready!
Step 7: Balloon Gun
Get a pipe, tube or a plastic bottle neck.
Trim the balloon a little bit shorter and slide it onto the tube.
Wrap it with an electrical tape.
Load your gun and you're ready to shoot.
Be careful. It's more powerful than it looks.
Never shoot at animals, people or somebody's property.
Step 8: Fancy Drink Cooler
Balloons make fancy drink chillers.
Fill them with the water, tie a knot and freeze them.
Colourful way to keep your drinks cool.
Alternatively, take the ice out from the balloons, revealing huge ice balls.
Probably you should not use balloons in direct contact with food, but if you do,
make sure to wash them.
Step 9: Drums
I did not throw away the balloon I used for the lampshade.
It was big, so perfect for a big drum.
I got a container from some kind of sweets and covered it with a balloon.
I also put a rubber band on top.
Now my neighbours love me even more :)
