$750.00 Garage Workshop
Intro: $750.00 Garage Workshop
The problem- I had so many tools stuck in boxes and bags for so many years that I ended up buying duplicates because I forgot what I had. I needed a shop that would allow me to keep my tools organized and readily available. I have a limited income, so going out and buying finished cabinets and storage units was out of the question. I am a McGyver by inheritance. My mother and father were both raised in the war years where things were in limited supply. They taught me how to create with my mind and then create by using what I could find.
I have just basic wood shop skills that I got in high school. But I wanted to have a nice workshop when I was able to set one up.Since high school my interests have run a wide spectrum. I have built guitars, amplifiers, stereo cabinets, Several kit cars, and I even built my own house. So I figured I could build my own shop. I first organized the shop plans for what I would be using it for.
1. Auto repair and customizing
2. Wood working
3. Electronics fabrication and repair.
4. Welding
5. storage of yard tools
Now that I have my garage all set up I figured I would share how to make the garage of your dreams on the cheap.
What tools you will need ( but not limited to)
1. Skill saw
2. Jig saw
3. tape measure
4. Shop yardstick
brill and various bits
5. 2 foot level
6. Speed square
7. 2 foot square
8 Table saw
Safety glasses, ear protectors and a clean workspace to lay out the items to work
Here are some finished photos of my garage before it was finished
2. Wood working
4. Welding
1. Skill saw
2. Jig saw
3. tape measure
4. Shop yardstick
5. 2 foot level
6. Speed square
7. 2 foot square
8 Table saw
STEP 1: Layout
Figure out what you will use the shop for and designate areas of storage and counter space to allow you to do that task.
Figure out how much space you can take away for the storage of family vehicles and still be able to walk around the vehicle(s).
STEP 2:
Fabricate base cabinets, wall cabinets, tool storage, and work cabinets
I used 4 types of cabinets in my garage
The first was Base Cabinets. These cabinets had to be easy to make, level, provide dust free storage, and be multi functional.
These were simple boxes made out of particle board to be supported by treated 2x4 bases, not unlike kitchen cabinets.
The second was wall cabinets. These cabinets too had to be easy to make, level, and be adaptable for many functions as well as be able to support what I planned on putting in them.
The third cabinet style was roll around. These had to be able to roll under the work top and provide a work top and caddy for whatever function I was using them for- welding, engine dis assembly, project work table, or tool caddy. Smaller rollers (2inch) were not easily pushed across the workshop floor and would hang up on extension cords, so I decided to use 3 inch rollers.
The last type of cabinet was for tool storage, parts storage, and chemical storage.
STEP 3: Base Cabinets
These cabinets sit on top of treated 2x4 frames and are bolted together as a unit. the basic box was either 16 wx22dx27h inches tall or 24wx22dx27h. A single sheet of 3/4 x 4x8 particle board will provide 6 sides and 2 bottoms. I cut the cabinets out and put them together as a stand alone unit. I used 2 inch drywall screws and wood glue to hold the cabinets together pre drilling a chase hole of 3/16 and a pilot hole 1/8 inch. A pice of 1x4 was used at the back top to hold the top apart as well as a 2x4 laid sideways at the top front. I leveled the base 2x4 structure and then set the base cabinets on top of this. the base structure was made to fit the span of cabinets and 20 inches wide to allow for a toe kick. The cabinets were screwed together and then fastened down to the base as well as thru the back plate to the wall. The back of the cabinets were covered by 1/8 inch perforated board as a means of keeping mice out and letting the cabinet breathe.
STEP 4:
Wall cabinets were made similar to the base cabinets except I made a channel 3/4 inch in from the back edge to allow 1/8 perfboard to slide in as a backer. The cabinets were made 48wx11 3/4dx 24 tall. I used a 1x4 laid flat against the rear edge and to the top side to provide support strength. In some of the wall cabinets I made special tool holders for spade bits, air fittings, and shelves as needed. One sheet of particle board provided enough material for several of these cabinets. Again, drill a 3/16 chase hole and pre drill 1/8 inch pilot hole for the screws. Particle board does not like to be fastened by forcing a drywall screw thru it.
These were hung by finding out how high I wanted them and measuring 3 1/2 inches down and using a chalk libe I set the position. I screwed 1x 4x 36 inch cleats to the wall and used the 1x3 at the back of the top of the cabinet to be my helper when I went to hang them on the wall. After the cabinets were hung I made a face frame out of 1x2 wood. I bought cheap door hinges and cut doors for the front out of bc 3/4 inch plywood. MDF board would work just as well and make a finished front.
STEP 5: Counter Top
The counter tops were made by using 3/4 particle board cut at 24 inches wide. Underneath I used scrap wood from cutting the base cabinets to ring the perimeter with glue and screws to hold them together. The top of the work bench need to be very sturdy so I used a 2x4 frame 22x 8 ft or cut to size to hold the counter top. This was screwed to the wall and screwed to the cabinet thru the flat 2x4 facer. I had a local sheet metal shop cut and bend a sheet metal top for the work bench putting a 1 1/2 channel at the front to cover the particle board top. This gives me a worktop not subject to damage and is easily cleaned. I ran copper lines thru the 2x4 platform for the top and put air chucks every 4 ft on the face of the cabinets to allow for easy use.
STEP 6: Tool Cabinets
One of my pet peeves has always been trying to keep my power tools clean from sawdust and debris. I constructed a 6 foot wide by 22 inches deep cabinet that had shelves made to fit my drill press, my band saw, my chop saw, and my various other power tools. A drawer section was made in the middle to store power tool attachments for my routers and other things related to power tools- wrenches, guides, jigs etc.
the size of this cabinet was dictated by some bifold doors that I picked up at a garage sale for 5.00 a set. This cabinet also sits on a 2x4 treated lumber base cut slightly smaller that the base of the cabinet. I made a face frame for the front of the cabinet and faced the front edges of the shelves with 1x2 lumber..
I made 2 more of these types of cabinets both were 4 foot by 11 3/4 deep. The height was determined by garage sale bifold doors I got for 5.00 a set . I put a 1/2 osb backer on these cabinets to attach to the wall and to help suppourt the shelves. One of the cabinets was for my auto supplies-jack stands, cleaners, rags, anti freeze, battery charger, oil, and spark plugs wipers etc. Shelves were measured and set to allow the most storage for the items needed. The other cabinet was set up to store yard tools- rakes, hatchet, shovel, hoe, machete, axe etc
STEP 7: Rollarounds
I made 5 roll arounds made like the base cabinets only I inset 3 inches on the backs and set up an extension cord storage and 4 gang outlet box. I also put 26 gauge metal tops on these and drawers on both sides to store nuts , bolts, screws, or in the case of the welder table I used the drawers for rods, cloves, magnets, cleaner, tips and extra tools that i would use. Plus store the small oxygen and acetylene bottles and extra hoses.
I also made a roll around for my table saw with drawers and a small cabinet to store all the jigs and accessories that are used with a table saw. On the back of this roll around i mounted an extension cord rack wit h a 4x4 4 gang plug. This allows me to roll the table saw anywhere in the shop or even out onto the driveway to use the saw.
My auto shop roll around was made similar but I put the extension cord on one of the sides so I could use more of the cabinet for tool trays and parts storage. The bottom shelf was set up to store my jack stands, floor jacks, and jack handles.
Rollers, drawer parts, handles, and doors were found at garage sales and purchased over a few years. But if you have the money buy em at Home Depot.
I will submit some more drawings and pictures as I find time. As always , a garage is a work in progress and is subject to each persons idea of what they want and need. I had very little funds and needed to finally get organized.
Some things that were left out-
I made a base cabinet to store my mini fridge
I made a tall cabinet to store my woodworking tools
I also made a lumber cart roll around
I am still not done, but I have spent under 750 to have a well organized workshop that my buddies complain about. Something about raising the bar? And the the comment-"don't let my wife see this..."
Some of the guys reading this will say that particle board is not strong enough to store things. To them i will just say- most kitchen cabinets are made of particle board covered with a vinyl facing, in these cabinets your wife stores a lot of heavy dishes and pots and pans. suspended from the wall and ceiling. How long have they survived kids crawling in them? I am going on 10 years with some of my cabinets and they have held up way better than I would have thought..
I have been collecting coffee cans from work and from friends to get my small parts under control
The red and black Folgers cans work out the best. If you see something I missed or have a question, please tell me. I am open to new ideas.
Buzz
Buzz
17 Comments
OhYeahThatGuy81 8 years ago
"They taught me how to create with my mind and then create by using what I could find."
The BEST way of learning, IMHO.
gurobuzz 12 years ago
joshdotk 8 years ago
Just out of curiosity, why wouldn't you run a Ford motor?
MENGA 12 years ago
gurobuzz 10 years ago
I found several on ebay at the right price and bought them quickly
DIYfan 12 years ago
especially if you seal and paint it
burnerjack01 12 years ago
at one time I had 4 in my yard, had to thin down the herd to 2
Tazmjm69 10 years ago
Thanks
For more ideas check out my tool storage--
https://www.instructables.com/id/Cheap-Tool-Box-Organization/step3/Wrenches/
mitsubob8404 11 years ago
Nice wheels too, but I think it'll be harder to convince the lady that we need a project ride compared to cabinets.
PS118 12 years ago
Also, I'm curious. What is that vehicle you're building? That looks pretty awesome as well!
Lectric Wizard 12 years ago
DIY Dave 12 years ago
pfred2 12 years ago
