Introduction: 8 Player Quizz Buzzer System Using Arduino
Advantage of this quiz buzzer circuit is once a team has press the switch others team may press the switch but only number. displayed on display who press switch first. So with the help of this circuit we can easily identify the contestant who has press the switch first. Let build the circuit using a ARDUINO NANO which read the input from push buttons and displays the corresponding number on a display device. It is a simple circuit with minimum number of components and easily can build. The ARDUINO takes into account the time delay between two buttons and the accurate number is displayed. When one of the buttons is pressed, the buzzer starts ringing and the corresponding number is displayed on the 7 segment display.
Step 1: Components:
2. Push Buttons x8
3. Resistors x8 2.2Kohm
4. Resistor 220ohm 1watt
5. 7 Segment Display
6. Male Female headers
7. Buzzer
8. 2N2222 npn transistor x1
9. Resistor 1kohm
10. 9v Battery & connector
11. Dot matrix PCB
Step 2:
Step 3: Circuit Diagram:
Here in circuit we are not using A6 & A7 pins of nano because there is no digital circuit present internally in the chip.
Step 4: Coding:
int x=1;// take int value as 1
void setup()
{ pinMode(A0,INPUT); //analog pins as input
pinMode(A1,INPUT);
pinMode(A2,INPUT);
pinMode(A3,INPUT);
pinMode(A4,INPUT);
pinMode(A5,INPUT);
pinMode(0,INPUT); //digital pins as input
pinMode(1,INPUT);
pinMode(12,OUTPUT); //Digital pins as output for seven seg display
pinMode(11,OUTPUT);
pinMode(10,OUTPUT);
pinMode(9,OUTPUT);
pinMode(8,OUTPUT);
pinMode(7,OUTPUT);
pinMode(6,OUTPUT);
pinMode(3,OUTPUT); // output for buzzer
// set initially display to 0
digitalWrite(12,HIGH); // seg a
digitalWrite(11,HIGH); // seg b
digitalWrite(10,HIGH); // seg c
digitalWrite(9,HIGH); //seg d
digitalWrite(8,HIGH); //seg e
digitalWrite(7,HIGH); // seg f
digitalWrite(6,LOW); //seg g
digitalWrite(3,LOW); // buzzer as off
void loop() {
int a=digitalRead(A0); // reading pin values for 8 buttons
int b=digitalRead(A1);
int c=digitalRead(A2);
int d=digitalRead(A3);
int e=digitalRead(A4);
int f=digitalRead(A5);
int g=digitalRead(0);
int h=digitalRead(1);
if(a==LOW) //if 1 player press button
{ if(x==1) // check if x is 1 if yes then execute the code
{ digitalWrite(3,HIGH); // buzzer on
digitalWrite(11,HIGH); // pirnt 1
digitalWrite(9,LOW);
digitalWrite(8,LOW);
digitalWrite(7,LOW);
digitalWrite(12,LOW);
x++; //increment x
else if(b==LOW) //if player 2 press button
{ digitalWrite(3,HIGH);// buzzer on
digitalWrite(11,HIGH); // pirnt 2
digitalWrite(6,HIGH);
digitalWrite(10,LOW);
x++; } }
else if(c==LOW) //if player 3 press button
digitalWrite(11,HIGH); // pirnt 3
x++; } }
else if(d==LOW) //if player 4 press button
digitalWrite(11,HIGH); // pirnt 4
x++;
else if(e==LOW) //if player 5 press button
digitalWrite(10,HIGH); // pirnt 5
digitalWrite(11,LOW);
x++;
else if(f==LOW) //if player 6 press button
digitalWrite(10,HIGH); // pirnt 6
digitalWrite(11,LOW); x++; } }
else if(g==LOW) //if player 7 press button
digitalWrite(10,HIGH); // pirnt 7
x++;
else if(h==LOW) //if player 8 press button
digitalWrite(10,HIGH); // pirnt 8
x++;
