Introduction: 888-606-4841-Customize Windows 10 System Sounds by Editing Registry Files
It would be a little bit surprising to know that – apart from start menu, logo, icons, and some features – Windows 10 OS brings in some new default sounds. And unlike previous Windows operating system software editions, it doesn’t allow you to turn them off from the control panel. Some sounds for log-on, log-off, and shutdown are not customizable in the way how you have done before.
But it is possible to customize them if you take the way through Windows Registry files. Though it appears to be unsafe for your crucial company data files, yet you can execute the practice carefully and successfully. If you are a novice user and you want to customize these sounds, you should access a reliable technical support for Windows 10, as a small editing blunder can cause your computer system to fail to reboot and reload the programs.
Based on your requirements, select a Windows 10 help desk technical support service that can help you take the task further with the utmost accuracy.
When you simply open the sound wizard, you find these sounds missing in the list. But they are simply hidden, as you can get them by editing entries in the Windows Registry.
· Click the Search box visible in the bottom-left corner
· Type regedit and press enter key
· Click the application that comes on the desktop after searching regedit
· Search the key: HKEY_CURRENT_USER\AppEvents\EventLabels\SystemExit
Once you get the result, you will get a DWORD in the regedit window with the label ExcludeFromCPL. You need to change the value from "1" to "0" and then click OK to complete the process.
In addition to it, you can also search two more keys – “HKEY_CURRENT_USER\AppEvents\EventLabels\WindowsLogoff” and “HKEY_CURRENT_USER\AppEvents\EventLabels\WindowsLogon” to get the hidden entries in sound control panel.
While the process requires you to be technically efficient to search hidden entries, it is necessary to get the process under an expert’s supervision. Selecting a right Windows 10 technical support can make a change while disabling some default sounds.
But a random selection can cost you more harshly as there are so many third party technicians available in the market. Before you choose a particular one, make sure what you choose has technical capability to handle your problem without causing additional issues. Dial Windows 10 customer service support phone number and choose a technician based on your requirements.
Editing Windows registry without a reliable technical support can be dangerous for your important data files. You should delve deep into the registry entries only when you can do it appropriately.
