Introduction: 8X8 LED Cube Take 2
this is my version of the 8X8 led cube. utilizing stacked Arduino boards for a low profile inside the box . all of the controls and status lights will be relocated to the outside of the enclosure on the sloped front panel. a PC Board will be designed to solder underneath the display case base. each row plus the ground will be connected by jumper cables. as will all of the status lights and controls one the front panel. everything connected to the stacked Arduino boards. the USB programing port, power switch, and power cord connections will be in the rear.
I had mirrored the case and back panel of the cube for more of a lighting effect. Everything else has been completed except for the PC boards and the power supply. I will post updates when finished.
