Introduction: 8x8 LED MATRIX DISPLAY | ARDUINO | BLUETOOTH CONTROL
In this tutorial i show how to build a 8 x 8 LED matrix using an Arduino .
DO COMMENT WHAT YOU THINK ABOUT THIS INSTRUCTABLE,SO THAT I CAN IMPROVE IN MY FURTHER INSTRUCTABLES
have a look at the video tutorial for a better understanding of the entire tutorial.
PARTS NEEDED:
☻LEDS( 64 PCs)
☻JUMPER WIRES
☻CARDBOARD PIECE(16 CM BY 16CM)
☻ARDUINO UNO
☻LAPTOP OR PC (FOR UPLOADING CODE TO ARDUINO
☻POWER SUPPLY ( I USED A POWER BANK TO SAVE BATTERIES)
Step 1: ASSEMBLE THE CIRCUIT USING CARDBOARD SHELL
PUT IN ALL THE 64 LEDs IN THE CARDBOARD PC AS SHOWN
Step 2: SOLDER THE LEDS AS PER THE CIRCUIT DIAGRAM
FIRST SOLDER THE POSITIVE TERMINALS OF THE LEDS ROW WISE
NEXTBENDTHE NEGATIVE TERMINALS A LITTLE BIT AND SOLDER THEM COLUMN WISE (AS SHOWN) ACCORDINGLY.
EDIT: JUST ADDED FEW EXTRA IMAGES TO UNDERSTAND THE SOLDERING PART A LITTLE BETTER
Step 3: SOLDER JUMPER WIRES AND POP THE CIRCUIT OUT
SOLDER 8 JUMPER WIRES IN THE ROWS AND 8 JUMPER WIRES IN THE COLUMN .
FINALLY POP THE CIRCUIT OUT OF THE CARDBOARD SHELL
Step 4: ARDUINO
CONNECT THE AURDUINO WITH THE LED MATRIX
CONNECT EACH OF THE COLUMN TO PIN 2,3,4,5,6,7,8,9 RESPECTIVELY
ALSO,CONNECT EACH OF THE ROW TO PIN 10,11,12,13,14,15,16,17 RESPECTIVELY.
FINALLY UPLOAD THE FINAL CODE TO THE AURDUINO THROUGH THE CONNECTING WIRE
To download the final code go to the below link :
https://drive.google.com/open?id=1rQIDh56OnBVF2rqVtHd0UK7_qQ4WNjcZ
Step 5: CONNECT BLUETOOTH
CONNECT THE BLUETOOTH DEVICE HC-05 TO THE AURDUINO:
connect rx of bluetooth to tx of arduino
connect tx of bluetooth to rx of arduino
vcc to +5v
gnd to gnd
Step 6: Download Android Application
download arduino bluetooth controller from playstore
Step 7: Let's Play With the App
click on connect and select your bluetooth device .
congratulations!! you have a working led matrix display controlled via bluetooth
