Introduction: 8x8 Red Dot Matrix With Arduino
You Need LedControl.h for Arduino IDE.
Step 1: What You'll Need
- Arduino or Arduino Clone
- 8x8 Dot Matrix With Driver Board
- 5 Male to Female Jumper Wires
If you get this stuff of eBay its about $10 AU.
Step 2: Wiring
- VCC goes into 5v on the Arduino.
- GND goes to GND.
- DIN goes to pin 12.
- CS goes to pin 11.
- CLK goes to pin 10.
Step 3: Programming
//worm#include <Ledcontrol.h>
int DIN = 12; int CS = 11; int CLK = 10;
byte arrowleft[8]={0x00,0x00,0x20,0x20,0x20,0x00,0x00,0x00,}; byte arrowright[8]={0x00,0x00,0x00,0x20,0x20,0x20,0x00,0x00,}; byte arrowdown[8]={0x00,0x00,0x00,0x00,0x20,0x30,0x00,0x00,}; byte arrowup[8]={0x00,0x00,0x00,0x00,0x00,0x38,0x00,0x00,}; byte somthink[8]={0x00,0x00,0x00,0x00,0x00,0x1C,0x00,0x00,}; byte somthink2[8]={0x00,0x00,0x00,0x00,0x04,0x0C,0x00,0x00,};
byte arrowleft2[8]={0x00,0x00,0x00,0x04,0x04,0x04,0x00,0x00,}; byte arrowright2[8]={0x00,0x00,0x04,0x04,0x04,0x00,0x00,0x00,}; byte arrowdown2[8]={0x00,0x00,0x0C,0x04,0x00,0x00,0x00,0x00,}; byte arrowup2[8]={0x00,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,}; byte somthink3[8]={0x00,0x00,0x38,0x00,0x00,0x00,0x00,0x00,}; byte somthink23[8]={0x00,0x00,0x30,0x20,0x00,0x00,0x00,0x00,};
LedControl lc=LedControl(DIN,CLK,CS,0);
void setup(){ lc.shutdown(0,false); //The MAX72XX is in power-saving mode on startup lc.setIntensity(0,15); // Set the brightness to maximum value lc.clearDisplay(0); // and clear the display }
void loop(){ printEduc8s();
void printEduc8s() { printByte(arrowleft); delay(50); printByte(arrowright); delay(50); printByte(arrowdown); delay(50); printByte(arrowup); delay(50); printByte(somthink); delay(50); printByte(somthink2); delay(50); printByte(arrowleft2); delay(50); printByte(arrowright2); delay(50); printByte(arrowdown2); delay(50); printByte(arrowup2); delay(50); printByte(somthink3); delay(50); printByte(somthink23); delay(50); }
void printByte(byte character []) { int i = 0; for(i=0;i<8;i++) { lc.setRow(0,i,character[i]); } }
Step 4: The Program I Used.
This will make it a lot easier to program.
comment and tell me if this was helpful at all.
