9 Volt Battery Hack!
Intro: 9 Volt Battery Hack!
Here is how to extract 6 AAAA batteries from one 9 volt ENERGIZER battery and use them like AAA batteries!
STEP 1: What You Need...
1 ENERGIZER 9 Volt Battery.
ATTENTION: I do not know if this works with any other type of 9 volt battery. If you try this and end up with something other than what I show you, then you are not using an ENERGIZER battery.
2. A pair of needle nose pliers and a small screwdriver
3. Optional: Gloves
3. Optional: Gloves
STEP 2: How to Do It...
Along the edge of the ENERGIZER 9 volt battery is a crease where the case is joined together. It is basically just crimped together to form a seal. Using the needle nose pliers and if needed, a small screwdriver, carefully peel apart the ENERGIZER 9 volt battery. BE CAREFUL!
STEP 3: What's Inside...
When it comes apart, you will find 6 "AAAA" or "quadruple A" batteries that each hold 1.5 volts, the same as a AAA battery. Remove the batteries and also the metal tabs that connected the batteries together.
STEP 4: How to Use Them...
Since these hold the equivalent voltage as a standard AAA battery, they can be used in a device that holds AAA batteries. The only difference is that they are a bit smaller in length. That's why you need the connector tabs. You can fold the tabs over and use them as shims between either the positive or negative side of the new AAAA batteries and use them in any device! Have fun!
115 Comments
DorianN4 5 years ago
Chuj w tą instrukcję!
jadon0506 11 months ago
Lefty the right 6 years ago
Alangar 6 years ago
I opened Panasonic Alkaline 6LF22PA / 6LR6PA / 1BDR (Made in Malaysia and bought in Dollarama in Canada) battery and it didnot work it. It had flat batteries inside. My tip is open the battery from bottom, and dont open too much. Just open bottom 25% you will be able to see if it has flat batteries or AAAA battery.
pompouschimp 7 years ago
I dismantled a 6LR61 Energizer 9v battery, expecting to get six LR61 batteries just like the video said. I was disappointed. I got six stacked rectangular cells (6F22?) instead. How is this so? Can anyone care to explain? I'm starting to question the authenticity of the product. Sheesh! I felt so ripped.
MickO6 6 years ago
Maybe battery tech has moved on in the 8n years since this article was written?
Daniel434 7 years ago
This is the best battery hack ever ! :)
mattj2 9 years ago
I tried energiser alkaline 12-2019 (black and silver), Panasonic NEO extra long life (black and silver), and Panasonic Hi-TOP long life (red and white) and they all had the flat cells, no AAAA's
cheezyguy5 9 years ago
Here's a tip, If the battery is a HEAVY DUTY or SUPER HEAVY DUTY battery, there will be a thick, toxic (if ingested) gooey paste, if it is a ALKALINE battery, there will be six AAAA battery cells inside.
YankeesFisherman123 10 years ago
ilpug 12 years ago
jordan4762 12 years ago
WakeUpWolfgang 12 years ago
jgilbert13 12 years ago
HeyJD 13 years ago
account3r2 13 years ago
HeyJD 13 years ago
But it was kind of like button cells stacked on top of each other.
It's just that these 'cells' were see-through and had paste inside.
superduperdrew 12 years ago
unclex6 13 years ago
