9 Volt Rechargeable Mini MagicMarilia Led Flash-light (awesome Blinding 600 Lumens Power in Your Palm)
4,078
26
5
Introduction: 9 Volt Rechargeable Mini MagicMarilia Led Flash-light (awesome Blinding 600 Lumens Power in Your Palm)
I embarked upon this project due to need, but it turned out well due to results. I hope you will enjoy it, as much as I did and get great power in your palm of your hand and best thing is you can recharge it. And keep the power for long long time.
Below I've outlined everything you might need.
Below are the 6 parts you need to buy : Estimated total cost:  $ 30 - $ 35 for project
1) Rechargeable 9v battery ($ 11 @ amazon)
2) Micro Push On/off Switch ( $ 2 at local hardware store )
3) 9V Battery Clip ($ 4 @ amazon) ( $ 4 @ amazon)
4) 10W Warm White High Power 800-900LM LED light Lamp Chip DC 9-12V  ( 700-800) lumens $ 2
5)  1  Ohms Resistor $ 2
6) Super Glue ( $1 @ dollar shop)
7) Micro Wiring
Additional requirement
1) 9V Smart Battery Charger ( $ 9 @ amazon)
To Construct : Yes, you actually have to build with stuff.
Hardware you need:
*Soldering Iron (Fine tip is needed)
*Solder
*Wire Cutters/Strippers
Benefits:
A: Super Bright, blinding Effect
B: Highly Cost effective
C: Rechargeable
D: Rugged and strong solid construction, Unbreakable (almost)
E: Waterproof
F: Weight 115 grams
G: Very small unit, easily fits in pockets, easy to carry
H: A perfect item for hiking and other outdoor sports,
Advice:
A: In case you run out of charge or lose it, so its good idea to make two 9v batteries.
B: My use is not more than 5-10 minutes in one go.
C: Please do not point directly into eyes
Lamps & Lighting Contest
Be the First to Share
    • Game Design: Student Design Challenge
    • Big and Small Contest
    • Make It Bridge
      Make It Bridge
    5 Comments
    chetancc
    chetancc
    8 years ago on Introduction
    What if I use same 9V battery as yours and not using 1 ohm resistor, is it ok or LED will get destroyed?
    redfox05
    redfox05
    9 years ago on Introduction
    is it a good idea to be fixing that LED to the battery, will this not heat up the battery and destroy it? Could be dangerous. Should attach this to a heatsink instead.
    dcr8tor
    dcr8tor
    Hi,
    nice project! Wanted to attempt this project, but I was curious:
    1) How did you manage to waterproof it? From what I see, the terminals are still exposed, and might cause a short-circuit.
    2) How long would it last on a single charge?
    Thomas
    bigjose
    bigjose
    9 years ago
    9v for the led 3.5v ...
    Nemesis201077
    Nemesis201077
    not the LED he refers to, it's 9-12v
