Introduction: A Bewitched Book
Bewitched Book
Intro:
Hello, this is my first Instructable. My project is a book that appears to be haunted. It will shake, laugh and glow green. The cover will try to open and sometimes the inside will glow eerily blue. I was inspired to make this project after watching a tutorial about how to make books look very old. I thought to myself, what if it was also haunted and did scary things every once in a while.
Please note; I was unhappy with the video so I have replaced it. Please be sure to turn up your volume to hear the evil laughter. Also the book didn't move or shake as much as I would like so I glued some plastic screw caps on the bottom. See last step for photo.
I get a lot of my parts from old electronics (printers, computers, radios, etc) that I take apart and scavenge the usable items from. Also, they can be found in electronic stores and surplus stores. The Arduino parts can be found on Amazon.
Step 1: Gather the Parts
One old book...................Please don’t use a classic. I found a 1929 Poetry reference book. It’s great because I didn’t need to age the pages.
One Arduino Nano
One ISD1820 Sound Module
One 8 ohm speaker...........The one that comes with the ISD1820 is not very good.
One Servo Motor
One Relay
One small 5 to 10 Volt DC motor
One weight......................I found mine in an old foot massager. Any small heavy piece of metal attached to the DC motor should work.
Three LEDs,.....................Two green and one blue.
One popsicle stick
Two small screws
Three resistors..................Three 220 ohm and One 1 meg ohm.
A peizo disk
One small on/off switch
Some Arduino wires
Some 14 guage wire
A small piece of 1/4” (6 mm) thick wood
A piece of clear plastic about 1/16” (2mm) thick..........I found in an inexpensive picture frame
Glue
Heat shrink and/or electrical tape
Step 2: Preparation
1. Hollow out your book. Leave about 25 pages at the top. The first 25 pages must remain uncut and unglued. Also leave about 1/2 inch (1.5cm) border or wall. I used a utility knife and a ruler to cut a rectangular hole. Go all the way to the back cover. My back cover wasn’t very sturdy. I cut the piece of wood to the same size as my hole, drilled a hole in the wood the same size as the DC motor and glued the wood inside the back cover to fit in my rectangular hole.
2. The green glow is achieved with the clear plastic. Cut it into strips a wide as or wider than the sides of the book. Glue them in various places between the pages. Make sure they are flush on the outside. Now, paint a coat of clear glue over the outside of pages.
3. Setup the ISD1820. I used a laugh I found on line but you can do your own.
There is a great tutorial on how to set up and use the ISD1820 right here at Instructables.
https://www.instructables.com/id/HOW-TO-USE-ISD1820-VOICE-RECORDER-AND-PLAYER/-----
A hint to make it easier:
Attached the ISD1820 to the your Nano 5V and ground. Plug the Nano into your USB.Now play the sound you want to record close to the microphone on the ISD1820. It is now loaded in the memory of the recorder. When you load the Bewitched Book program it will m play the sound when the corresponding Nano pin goes high.
4. The Servo Motor comes with several small white arms. Drill two holes in the popsicle stick and screwed it to one of the arms. The white arm that only protrudes in one direction is best. Gently turn the servo motor arm clockwise until it stops. You could alternatively write a short program to set the servo at 0 degrees.
5. The Relay is for the DC motor. Connect the main power wire to the common connector and the DC motor positive wire to the N.O. (normally open) connector
6. Solder the 220 ohm resistors and wiring to the LEDs as shown in the picture. Remember to cover any exposed wires with heat shrink or electrical tape.
7. The Piezo disk should have a wire soldered to the brass colour and a wire soldered to the white center portion. One wire is attached to ground and the other to an analog pin of the Nano. The wires need to be long enough to go through the pages to the inside cover of the book. Also, the one Meg resistor must be soldered between the wires somewhere along the lines.
Step 3: Programming
. Due to the tight space, you may want to load the program onto the Nano before placing the Nano board into the book. You can check the comments in the code to change how much delays are between actions.
The code is Here:
In the video I have set the delay between actions to one second (1000 milliseconds) so that the video didn’t run too long. Normally, it should be set around 30 to 60 seconds (30000 to 60000 milliseconds) to make it’s actions more unexpected. You can see this in the code comments.
[code]
/* Bewitched Book Sketch by John Shute (not a pro by any stretch of the imagination). I declare
this code to be public domain and I except no responsibility for anything.
The code will control several functions intended to make a book appear to be haunted.
#include <Servo.h> //Library
Servo servo; //declare the servo motor
int pos = 0; //position variable
int i = 0; // count variable
int val = 0; //value for knock sensor
const int KnockSensor = A0; //knock sensor
const int THRESHOLD = 350; //How hard a Knock to start Cases (o to 1023)
int pwmLED = 5; //Green Fading Leds
int pwmLED2 = 6; // " " "
void setup() {
Serial.begin (9600); //for debugging
pinMode(A0, INPUT); // Knocksensor Pin
pinMode(3, OUTPUT); // Open book
pinMode(4, OUTPUT); // Rumble Motor
pinMode(7, OUTPUT); // Blue light
pinMode(8, OUTPUT); // Evil Laugh
pinMode(pwmLED, OUTPUT); // Green Fade (pin 5)
pinMode(pwmLED2, OUTPUT); // Green fade (pin 6)
void loop() {
sensor(); // check the sensor
haunt(); // start the program
void sensor() {
val = analogRead(KnockSensor); // read the knock sensor
if (val < THRESHOLD) { // if sensor not activated,
sensor(); // keep checking
else { // if the sensor is disturbed
haunt(); // go to haunting actions
void haunt() { //begin actions
delay(5000); //wait 5 seconds
// Rumble Motor, Relay to rumble motor turned on, book vibrates
digitalWrite(4, HIGH); //turn on the rumble motor
delay(700); //run 7 milliseconds
digitalWrite(4, LOW); // stop
delay(20000); //wait-----CHANGE THIS VALUE TO ADJUST THE DELAY BETWEEN ACTIONS.
//(1000); IS 1 SECOND. (60000); IS 1 MINUTE).
// Evil Laugh, recording plays
digitalWrite(8, HIGH); // recording plays
delay(3000); // time for recording to play
digitalWrite(8, LOW); // stop
delay(17000); //wait...The delay between actions.
// Pages Glow Green Fade in, then out.
for (int i = 0; i < 255; i++) { //set the rate of fade in-increas i by 1
analogWrite(pwmLED, i); //write the i value to pin 5
analogWrite(pwmLED2, i); //and 6
delay(5); //time between iterations
analogWrite (pwmLED, HIGH); //after 255 write high
analogWrite (pwmLED2, HIGH); //
for (int i = 255; i > 0; i--) { //decrease i by 1
analogWrite(pwmLED, i); // see above
delay(5);
analogWrite (pwmLED, LOW);
analogWrite (pwmLED2, LOW);
delay(20000); //wait...The delay between actions.
// Book Open and Close, blue LED on
servo.attach(3); //turn the servo on
for (pos = 0; pos <= 35; pos += 1) { // goes from 0 degrees to 35 degrees in steps of 1 degree
digitalWrite (7, HIGH); // bue led on
servo.write(pos); // tell servo to go to position in variable 'pos'
delay(100); // set the speed it moves, relatively slow
for (pos = 35; pos >= 0; pos -= 1) { // return to 0 degrees
servo.write(pos);
digitalWrite (7, LOW); // tell servo to go to position in variable 'pos'
delay(15); // close quickly
servo.detach(); // servo off
delay(14000); //wait...The delay between actions.
// Rumble With Green light,
digitalWrite (pwmLED, HIGH); //green light on too
digitalWrite(pwmLED2, HIGH);
delay(500);
digitalWrite(4, LOW); //turn them off
digitalWrite(pwmLED, LOW);
digitalWrite(pwmLED2, LOW);
delay(21000); //wait...The delay between actions.
// Evil Laugh
digitalWrite(82, LOW); // stop
// Book Opens with no light
servo.attach(3);
for (pos = 0; pos <= 35; pos += 1) { // goes from 0 degrees to 35 degrees Steps in steps of 1 degree
delay(100); // go slowly in this direction
delay(500);
servo.write(pos);
delay(15); // waits 15ms for the servo to reach the position
servo.detach();
delay(19000); //wait...The delay between actions.
// Green Fade
analogWrite(pwmLED, i); //write the i value to pin 5 and 8
delay(5); //wait 5 ms then do the for loop again
delay(5);
delay (20000); //wait...The delay between actions.
//Rumble
delay(500);
// Evil Laugh
delay (15000); //wait...The delay between actions.
// Book Open
servo.attach(3);
delay(500);
servo.write(pos);
servo.detach();
//Book Open with Blue Light and Laugh
digitalWrite (8, HIGH);
delay(100);
servo.write(pos);
digitalWrite (8, LOW); // tell servo to go to position in variable 'pos'
delay(15);
servo.detach(); // turn the servo off
delay(140000); //wait...The delay between actions.
haunt(); //Go back to the Haunt loop
[/code]<br>Step 4: Assembly and Wiring.
Step 4 Assembly and Wiring.
Glue the DC motor firmly into the hole drilled into the board. Insert the other parts. The wiring diagrams will illustrate how I placed the components. Glue them in, too. You need to cut a small slit in the top 25 pages to slide the Piezo disk through and tape the disk onto the back of the front cover. Cut a hole in the pages where it won’t show and install the switch. Try to keep the LEDs close to the front of the book.
Wiring is a lot of work. I uploaded two diagrams
When wiring use the power line diagram first, then add the control lines.
The Nano board has a 5 volt regulator on the Vin pin so it and the DC motor are connected directly to the battery, through the on/off switch. All other components get 5 volts from The 5V pin on the Nano and are grounded to the Nano Gnd as well.
Step 5: Test and Adjustments
Once you turn the switch on the book may do a few actions such as the DC motor rumbles and the recorder plays. It takes a second or two for the Nano to start and control things. After this nothing should happen until you knock on the front cover. Then in five seconds the actions should begin.
You only want the servo motor to open the book slightly, otherwise people could see into your book. If it doesn’t open the book at all you could adjust the code or, an easier way is as follows. Turn the book off, take the popsicle stick off the gears and place it back on at a higher point in its cycle.
Step 6: Making It Look Old.
I glued some plastic screw caps on the back of the book so it would move better. See photo
Now we have to make our book look ancient. The best way I have found, and it’s not to difficult, is to follow this lady’s instructions, here.
https://www.youtube.com/watch?v=zPrkBor5TxM
So, I hope this project was as fun for you as it was for me. Also, I hope you get to startle a few friends and family this Halloween.
