Introduction: A Bracelet for a Wood Worker
This year I got my own little workshop. Something I have dreamed about for years, so now it’s time to celebrate. I celebrated with making a nice bracelet: a bracelet for a woodworker. It looks beautiful and it is not too difficult to make. I wear it also at my job as school teacher (in Sweden), and this inspires my pupils (age 12 to 15) to also make their own bracelets.
Step 1: This Is What You Need
To make the plate:
- Brass, copper, silver or aluminium 1mm
- Metal shears
- Rasp for metal
- Glue, paper, picture/template
- Jewelry saw, saw blade for metal no 3
- Nails or rivets
- Pillar drill or drill
- Rotary tool and buffing compound
- a wooden form (ellips) to bend your plate in the right from
To make the bracelet:
- Leather about 2mm-2.5 mm (3/32 inch) thick if you use thinner leather the bracelet will become fluttery
- Sew thread and sewing machine or leather needles (optional)
- Leather wax, piece of cloth
- Cutting board
- A breakaway knife or sharp carving knife
- Hardware: lock I choose snap fasteners but you can also use Solid Brass/Silver Globular Round Head Stud
Spot Screwback Back (that’s the name on Ali express ;-)
- Rivet setter or make one yourself by drilling an indentation in hard metall
- Punches, wooden mallet and awl
- Stuff to burnish the leather (optional)
Step 2: Cut the Leather Strip
Start with measuring your wrist. The leather band should be one inch longer for overlap the bracelet with the fastening. Take care that you have some extra space as you don’t want to have your bracelet to tight.
Cut the leather at the right length. You can use a leather belt or cut the bracelet from another piece of leather. Once I did a bracelet of the leather from the back of an old chair which would be disposed. My wrist measures 6.3 inch (16 cm) and I cut the bracelet with the length of 7.7 inch (19.5 cm). It is 0.8 inch (2 cm) wide.
Step 3: Burn the Edges
To burn the edges is optional but it gives a professional look when the edges are burned. Though I’m not used to work with leather I searched for an instructables on how to burn (polish) the edges and I found this wonderful instructables
https://www.instructables.com/id/how-to-burnish-le... ….
But then I do not have the time to polish the edges by hand which will take hours and I found the following instructables: https://www.instructables.com/id/Wooden-Leather-B...
Yes it burns your edges in just a few minutes, I like it. I decided to turn a "burnisher" on my lathe. I burned the edges on the following way : I took a plate with water. I wetted the edges by dipping it in the water and burned on the lathe at a speed of 1350rpm
Step 4: Sew the Leather Strip (optional)
I recomment to sew the sides of the bracelet if you have access to a sewing machine able to sew in leather, it gives a more professional look. My sewing machine is 55 years old and very strong so I gave it a try and it worked out fine although I had to help my machine a bit.
But don't panik the bracelet looks very well without the sewing or you can sew by hand, Jessyratfink shows us how to sew in leather by hand, look here
Step 5: Prepare the Plate
Cut out your plate 0.04 inch (1mm) with a shears or cut it whith your jewelry saw(The measurements are 2cm by 4,5 cm) and use a rasp to smoothen the edges.
Glue the design on of the copperplate with glue. This makes it easy to remove the paper afterwards. Let dry. you can either draw your own design or find it on internet when you search on "free templates". Before you start to drlll: Make an indentation with a nail and a hammer to prevent the drill from slipping away.
When your design contains very small details you can drill some holes in advance.You will get some burs on the backside, so smoothen with a rasp.
Step 6: Cut Your Design
Prepare your jewelry saw and cut your design. I used a blade for metal number 3. Take your time and hold your jewelry saw uppright. Don't force the saw and dont't forget to relax your shoulders while sawing.
Remove the picture after wetting when you’re done and use a rasp to smoothen the edges.
Step 7: Buff the Plate
Before buffing the plate sand it to remove all the scratches. I startet with 240 and ended with 1600 grit. I buff the brass plate to get rid of the scratches and to get a shiny surface. I used a Dremel. If necessary clean with alcohol or dish with soap and hot water.
Make an indentation at both ends with a nail and a hammer if you haven't done this in a earlier step. This is to prevent the drill from slipping away when you drill the two holes for mounting the bracelet on the leather
Step 8: Mount the Plate on Leather Strip
Tape your plate on the bracelet, this will also prevent the plate from scratching. Then tape the bracelet on the form. The wooden form is an ellipse and is 6.7 inch (17cm) circumference/outline, 2.4 inch (6 cm) x 2 inch (5 cm) and1.6 inch (4cm) high. This form makes it easier for you to bend the plate in the right form (a slight bent because your wrist is round) and it will make it easier to drill the holes.
Bend both ends of the plate down on the bracelet while you still press the center of the plate on the bracelet with your thumb or a clamp.
Drill the holes through the plate and the leather bracelet. I used a 0.08 inch drill. This size depends on the size of the rivets you will use (the size of the cylindrical shaft). You will get some burs on the backside so smoothen with a rasp.
Place the rivets in the holes. I used brass nails instaed of rivets and it worked fine too. Cut off the extra length. You should leave 3/4 of the diameter of the rivet. Use anvil tools to clinch your rivets, or drill an indentation in hard metal if you don’t have an anvil tool. Put the head of the rivet on the tool in the anvil. I placed a piece of thin fabric between the tool and the rivet to prevent marks on the plate.
Flatten the rivet with a hammer and smoothen afterwards with a rasp if needed.
Step 9: Fasten Your Snab Fasteners
Make a hole on both sides of your bracelet. I used a hollow punch tool. You can also drill your holes with a drill or use or a leather hole punch. The size dependents on your Snab fasteners.
Fasten your snab fasteners on both sides. How you should fasten your fasteners is depending on which brand you have chosen. If you feel unsure than look on the internet there are loads of instruction videos which show you how to fasten just your type of fasteners for example:
https://www.youtube.com/watch?v=4P1siZ_HeQc
Or look on the pictures above to get some help if you use the same press fasteners. I bought my Press fasteners here: http://www.slojd-detaljer.se/kategorier/textil-lad...
Step 10: Enjoy Your Bracelet!
I hope you liked this instructable. It competes in the Jewelry Contest. Good luck by making your own bracelet and don't hasitate if you have some questions.
Have a nice day, Amaries.
Jewelry Contest 2017
23 Comments
5 years ago
What a nice bracelet!
5 years ago
judging people down is bad, a polite corection wins the heart
5 years ago
Thank you kenthehats. Well teachers have also weekends :-) Show some Pictures of your resolts theat would be nice. And thank you also for your vote, it made me very happy.
5 years ago
Surprised you have the tkme as a teacher many many thanks..i made a strip wood ring and found coin rings a real headache ..but these of your are superb ..and my first design will be the Viking Thor hammer followed by a Wolf design..in between playiing guitar and reading I shall be scouring charity shops for leather belts etc..lol..I have voted this for its ease of making and the way you offered help emails withkn your entry..K.Wolf.
6 years ago
Very Nice , Looks Great !
Reply 6 years ago
I'm glad you liked it!
6 years ago
Thank you for your inspiring instructable, Amaries. This is on my list of fun things to make now. Well done!
Reply 6 years ago
Nice I am looking forward to see the result if your list is not too long :-)
6 years ago
Very nice instructable. Never been a big fan of those that find fault in another's spelling as I also tend to make typos from time to time. As far as the work itself, there is only one thing I would suggest as a leather crafter since 1991... never, never ever, NEVER use a steel hammer on a punch or other leather tools. Use a poly or wood mallet to keep from 'mushrooming' the head [striking end] of the tool. I have the original punch and setting tools from when I started. I have seen many people destroy these and replace them over and over. Nice touch with the stitching. Igen, bra jobbat
Reply 6 years ago
Hello Lethrwolf thank you for your compliment and the usefull advise about the mallet, I will keep this in mind! And I'm impressed about your language skills both in Dutch and in Swedish :-)
6 years ago
Dear all,
let’s drop the spelling issue Bryan has made a fair apologize. Let’s focus on our
fantastic creative community.
6 years ago
I really really like it!
Reply 6 years ago
Thank you, that was kind!
6 years ago
To the comment on aluminium... You proved your point, but do not lump all Americans into the group of illiteracy and remember ''one of the oldest digital technologies available to them: The mighty spell checker! :)'' The proper spelling is ALUMINUM. REALISE is REALIZE. Proper sentence structure should not be: ''you were not first language English'', but should read: 'I did not REALIZE your first language was not English.' Guess you wish you hadn't posted your comment hastily. People should not lose the essence of a tutorial with trivial things like spelling. To Amaries, don't fret your spelling, it is better than some I have seen from English first writers. OH the horrors you would see if I had to write in Dutch. We merken van de fouten van anderen en gemakkelijk vergeten onze eigen.
6 years ago
It appears the author is someone for whom English is a second language (or so) - see profile, thus the difficulty with spelling. Normally I'm nitpicky about spelling, however in an international forum such as this, I suspend my nitpickiness in favour of enjoying the creativity & execution of projects such as this.
Reply 6 years ago
My apologies Amaries, I did not realise you were not first language English and should have read your bio before commenting. I work with many Swedish people, and I must admit, their English is better than most English people I know! I guess this is not always going to be the case.
As I am unable to speak, write or spell any Swedish dialects, I would not know for sure, but I am certain you also see a huge decline in spelling and language skills in the modern internet age. It's a very sad situation.
People forget one of the oldest digital technologies available to them: The mighty spell checker! :)
You did spell aluminium correctly, so you are miles ahead of everyone in the US of A already, and for that I am grateful.
Now I am off to make a particularly lovely Swedish woodworking bracelet using copper metal, rivets, pillar drill, rotary tool and sewing thread.
Thanks again for the instructable!
Reply 6 years ago
Thank you BryanS181 I corrected the spelling in the instructables and have fun with making your bracelet.
Reply 6 years ago
And so it is, thank you
6 years ago
What a creative take on a traditional piece. The possibilities are endless! Thank you for sharing
Reply 6 years ago
Yes you are right endless possibilities :-)
