Introduction: A D.I.Y Pull-back Mini Racer Using Wind-up Spring
About: I am an avid reader and a computer science enthusiast. Currently, I’ve been investing my time in meaningful and productive pursuits building something that truly matters. I’ve authored several eBooks, includin…
Ah.....pull back micro racers. We all had them in our childhood. Let us bring our childhood back once again.Presenting all new D.I.Y( do it yourself) pull-back car with monster body. Let us dive deeper to understand the mechanism behind the working of this project/model.
Components Used :
  1. A set of 5 gears
  2. Wheels of suitable diameter
  3. A wind-up coil spring - it can generate counterpart rotational torque when winding up.
  4. A plastic chassis and body to cover it
Step 1: A Set of Gears
Key points regarding this project:
  1. To be more precise, it's basically just a spring compressed gear and a gear ratio amplifier, so that way the torque is lower and the speed is higher. It also has a clutch-like mechanism, so that way it decouples the spring mechanism from the axle if you want to just push the car forwards.
  2. It could be build at home out of 3d printed parts.It is fun seeing these types of gadgets going at lighting speed then crashing or falling instantly.
Fun Time: Put the eraser on it and ride it to your friend and see it flying due to momentum, not the car but the eraser.
Step 2: Assembly of Gears
We often neglect the fact that our childhood has gone through playing with multiple toys of different shapes and varieties.
We didn't know anything back then but now we all have grown up and it is the high time to uncover the mechanism behind working of a pull- back car.
This project requires basic knowledge of gears and how they work in an arrangement
Step 3: Naked Spring - Absolutely Not a Thing to Play With
Winding up a spring by holding the center between thumb and index finger and pulling on the end with your other end is the perfect way to get 6 perfectly parallel cuts on your thumb that are nigh impossible to stitch up.
Yes, I was a stupid kid.
Step 4: A Visionary Approach
You may build something out of the box (a visionary approach) :- If we could make this thing hundreds time bigger then we can power that with hydraulic engine with power of crankshaft by hands or by weight or by sea saw so we get lots of free electricity for charging many gadgets.Use very strong spring which turns the flywheel and it turned the dynamo so that we get continues supply of energy and electricity production become smooth for an hour and we can use our weight as power source if we make foot operated hydraulic system.
