Introduction: A Float Sensor Cane
This is an Arrangement of Float Sensor on the Desired tank water level so that it won't get falsely triggered,
This #Juggad is made up with help of CPVC Pipe and CPVC Fittings.
Step 1: The Problem
Installing a Float Sensor is not so easy job, to keep in a set position.
To avoid the problem of false self-triggering in the circuit in the case of Float Sensor, To overcome this problem Presenting here,
" A Float Sensor Cane "
Step 2: Components List
CPVC Materials
  • End Caps (4)
  • L - Joint / L - Bow (2)
  • T - Joint / T (2)
  • Pipe (According to Your Tank Height)
Float Sensors (2)
Cable Gland (1)
Step 3: Making Gland Conector
First, take an End Cap make a hole on it then connect the Gland Connector for a watertight wire cable.
Step 4: Making Float Sensor
Take another End Cap, make a hole on it and connect a Float Sensor on it, do it Two times, or repeat the same process for Multiple Levels.
Step 5: Assembling Fittings
  1. Take a T- Joint cut a small piece of pipe connecting it to the center of the T- Joint.
  2. Take an L- Joint, connected it to the center of the T- Joint.
  3. Cut another small piece of pipe connects it to another end of the L- Joint.
  4. Now connect End Cap with Float Sensor on the same end of L- Joint.
  5. Do it Two times, or repeat the same process for Multiple Levels.
Step 6: Connect Pipe
Now, Connect Sensor Joint on Pipe as per Tank Water Level Height.
Step 7: Gathering All Joints
  • Connect Gland ConnectorJoint on Top of Pipe.
  • Connect Float Sensor Joint on the height of Desired Water Level.
  • Can make Multiples Float Sensor Joint for Multiple Levels.
  • Adjust Sensor Position as per Circuit Requirement
  • Connect an End Cap on the Bottom of the Pipe.
Step 8: Make Your Own Float Sensor Cane
Make Modifications as per your Needs / Requirements.
Add more Levels for more Precision.
Adjust Sensor Position according to Circuit.
Stay Tuned...!
Step 9: " Rakshan Jalam Rakshati Jivnam "
This Float Sensor Cane can help us in saving a lot of water which usually just gets wasted.
Thank you so much for coming here and reading this article.
Hope this article has helped you..!
For any further queries, you can drop your valuable opinion and comments in the comment section.
Thank you so much!
“ Save Water, Save Life “
