Introduction: A Flower Rack Made of Tiles and Wood
Mission: Waste materials recycling, saving and environmentally friendly!
Note: This is the work of a decade ago, there were only finished photograph, the following production process photo camera works is open again. So the tiles have been drilling.
Once, a group of furniture custom installation, after completion, the remaining number of bits and pieces.
Step 1: Materials
There are a few short board stripe, and got two remaining tiles.
Step 2: Location
The use of cross-section of the end of the strip, drew lines on the tile. And positioning the screw hole.
Step 3: Tile Drilling
To tile drill, impact drill with diameter 4 mm, first with the nail gently tap the location, and then use the appropriate items (such as brick) liner steady, careful force. Then using the holes on the tile, to make a mark on the end portion of the strip cross-section, for fixing screws accurately.
Step 4: Slats Drilling
Mark the guide hole for the screw with the smaller diameter (about 50%) of the drill in the cross section of the slat end according to the hole mark defined above.
Step 5: Assembly
Install the three slats and two tiles with old screws that are collected daily. Note that the screw head is different, that is ,with the tile surface is a plane and cone surface two, as shown in the figure up and down type.
The installation is complete, as follows, and paste cushion at a bottom surface of the tile-equilibrating position contacting the ground.
Step 6: Finished and Used
Successful!
