Introduction: A Mini Shelf
I made a shelf that will help my father be more organized in his garage because we had recently moved into a knew house that has less space in the garage so I decided to make something that will help improve my dad organizing in his garage and when i told my father about this he really appreciated it and gave me feedback on what to do and how i should do it.
I started in tinker CAD and put together something that looked like a shelf as best as i could and then i started shaping up the small details like lining up the square so that nothing would be unaligned and then i showed it to my dad and he told me that he didn't need as much walls inside the shelf so i should take one out so he could have more space inside.
Step 1: Desighn Your Product
First you want to design your product in the website that will put that info in the laser cutter and cut the pieces you need which I did above.
Step 2: Get the Peices
After the laser cutter cuts your pieces you want to glue then together, this is my first prototype and which mine is made out of card board box and then you use hot glue to glue it together for your first prototype
Step 3: Repeat
Put the information back in the laser cutter website and then have the laser cut your pieces but in wood this time but this time you want to get feedback from your client and switch things up to make it better.
Step 4: Final Product
After you get all the pieces you want to glue it all together by using dry glue this time and leave it over night so the glue can dry and then you have your final product
