A Packet of Sugru Goes a Long Way-Go Bananas!
872
8
Introduction: A Packet of Sugru Goes a Long Way-Go Bananas!
I had several projects and repairs and a packet of yellow Sugru. I accomplished all of them and more using a bit of black Sugru my friend had leftover. Here's what I did:
1-Added antennae to my Bee Sunglasses
2-Added horns to my black sunglasses
3-Repaired a necklace chain and added a bead too
4-Fixed a broken zipper pull on my binoculars case
5-Patched a tear in my hiking shoes
6-Repaired my iPhone charger cord
7-Made a hexagon "rubber" stamp
You have 30 minutes to work with the material once the packet is open, so I strongly suggest having your projects all laid out and ready before opening the pack. I used a glossy paper plate as a work surface to keep the yellow clean and keep it from sticking to the table.
Step 1: Custom Bee Sunglasses
I sculpted little antennae and added them to the sunglasses I'll be wearing with my Queen Bee costume this Halloween. First I shaped them and attached them, later I added tiny black stripes. I like the custom touch!
Step 2: Add Horns to Sunglasses
I shaped some little horns, or cat ears, if you like, to make these plain sunglasses more interesting.
Step 3: Fix Broken Necklace Chains, Add a Bit of Color
This delicate necklace chain kept breaking from the clasp. I used a tiny piece of Sugru and bonded them together forever. I also made a little bead and dangled it from a jump ring to give the tassel necklace a bit of extra weight and a pop of yellow. Super!
Step 4: Repair a Broken Zipper Pull
I sculpted an ergonomic little handle for the zipper on this case where the metal zipper pull had broken off. There was a little piece sticking up from the zipper head and I mushed the Sugru onto it. Voila! You can now easily zip and unzip the case.
Step 5: Repair a Torn Shoe.
My hiking shoe had torn and was only getting worse, so I made a banana and pressed it onto the shoe, covering the hole and attaching the Sugru to both the mesh and the leather. This should stop it from tearing more and adds a bit of interest to these drab hikers.
Step 6: Go Bananas Repairing Your IPhone Charger Cable
Instead of just putting a gob of Sugru on my fraying cord, I made a banana that wrapped around, fixing the damage and giving it more structural integrity where these cords always break. Once again, a banana saves the day!
Step 7: Reuse Materials to Make a Stamp
I needed a hexagon shaped rubber stamp to put some detail on my Queen Bee costume, so I used some leftover Sugru and a bottle cap. I put a blob of Sugru on the cap, smushed it flat and cut the shape with a utility knife.
As you can see, I made alot of projects out of just one package of Sugru (plus a little leftover from my friend's pack). You get 8 packs for $22, so that's a good deal for such a versatile material. As soon as I was done with these 7 projects, I thought of 7 more. Good luck, you are only limited by your imagination with this stuff.
Fix & Repair Contest
Be the First to Share
    • Edible Art Challenge
    • Laser Challenge
      Laser Challenge
    • Hide It Challenge
      Hide It Challenge
    3 Comments
    CityGirl70
    CityGirl70
    7 years ago on Introduction
    Thanks for sharing. I've never heard of the stuff until now. I went to the website and ordered a mini pack to test out.
    ceejwells
    ceejwells
    Reply 6 years ago on Introduction
    I'm curious, what did you use the Sugru for? Did it work?
    Tater Zoid
    Tater Zoid
    These are all great ideas. Thank you for joining us for Sugru Night.
