Introduction: A Picture Taking Bear
I made a bear that has a camera inside of it. it has Velcro inside of it to hold the camera in place, more on the back to close the hole you look through, and some on the neck part you open up to get the picture out. I used rope to make straps to carry it around like a back pack and I tied knots at the end to keep it in place. I have also added fairy lights for a back light and so you can see on the inside what you are doing. and the last part of the design is I have added a wooden dowel rod attached to the hand and button so when you push down on the hand the rod will put pressure on the button to press it.
supplies you need is a bear, camera, felt. Velcro, rope, fairy lights, and 2 wooden dowel rod. tools you need is hot glue, tape, a seam ripper, scissors, needle, and thread
Step 1: Take Out Stuffing
first you need to rip the seam on the back with the seam ripper and take the stuffing out
Step 2: Camera Hole
draw and cut hole in stomach for camera
Step 3: Camera Fitting
take the camera an put it in the back and let it stick out of the whole to see if you need to cut more or sew something up
Step 4: Putting Camera In
once you have made the hole a size that fits your camera or a size that you would like, hot glue the Velcro to attach the camera to the inside of the bear
Step 5: Neck Hole
next you need draw and cut the head a little less that half way so when the picture cones out of the top so you can get it out. when you have cut the hole you need to hot glue Velcro to the in side of the head and the out side of the chest so you can open and close it
Step 6: Fairy Lights
next you need to add fairy lights inside the bear so you can see what you are doing
Step 7: Straps
next you are gonna need 8ft rope next you are gonna cut it in half. after that to are gonna cut 4 holes one on the upper part of the back and the other one on the bottom then after that you put both ends to the ropes an tie the end so it doesn't fall out and it stays in
Step 8:
nextis the dowel rod, you are gonna take the rod hot glue against the back of the bear so it will keep the head straight
Step 9:
next you are gonna take another wooden dowel rod and glue one end to the hand and the other to the button so when you push the hand down it presses the button.
Step 10:
lastly you are gonna get needle thread and felt cut a circle that fits the neck size and sew it on to the hole so the stuffing in the head doesn't fall out
