A Punch of Thousand Volt
Intro: A Punch of Thousand Volt
STEP 1: Material Required
#1. Hand glove with long wrist strap.
#2. 3.7 volt li-ion battery.
#3. Voltage multiplier circuit board (I get it from electric fly swatter).
#4. Thumb pin (big one). Four of them.
#5. Hot glue sticks and gun.
#6. Needle and Thread.
#7. Balloon.
#8. Adhesive glue.
#9. Soldering iron.
#10. Scissor and some common other tools.
STEP 2: About the Circuit Board
#1 The first part of circuit is charging part which charges 4 volt lead acid battery by main supply(250 volt).
#2 Second part consist of transistor,resistor and transformer which convert the direct current of battery into A.C signal and further amplified by the transformer in higher A.C voltage.
#3 Third part of circuit is a voltage multiplier which multiply the voltage came from transformer and store it in capacitor (A very high DC voltage).
I tried to measure the voltage by my multimeter by setting on its highest rang that was 1000 volt but voltage was more than that as meter had a big spark and was over the rang but it would not be more than 2000 volt as capacitor max voltage is 2kv (written on it).So the voltage may be between 1000 to 2000 volt.
STEP 3: Trimming the Circuit Board
STEP 4: Soldering Wire to Circuit
The negative input wire will be soldered at the end of the transformer 4th pin as show in the image.
Positive wire will be soldered at mid pin of the transistor which is the collector pin in this case, the transistor might be D882P or something similar to that.
STEP 5: Hooking Up the Thumb Pin
For this we need thumb pin which you can get from a stationary store just ask for the big one they must have it. Now for hooking ,bend the pin in one direction (90 degree) from beneath, so that it becomes like a hook, now we need to sew the wire from inside net of the glove, for this we have to hook up a needle with the wire and sew it up so the wire can be hidden. I used some of the hot glue to place the pin. Further i came to know hot glue was necessary as it stop the capacitor to discharge.
STEP 6: Adding the Switch
I used very small button switch which is in ON state only and up-till we press it , i placed it beneath the glove first finger and the wire is from the behind the net, sew it from needle and hot glued it to seal it.
STEP 7: Adding the Battery
The lead acid battery which is pri-fitted in the racket we don't need it as its too big, so i used a lithium ion battery of a cell phone, ripped off its cover and protection circuit and attached a positive and negative lead. This battery are compact and long lasting.I first used adhesive glue to place the battery on the wrist belt then sewed it there.
STEP 8: Adding Circuit Board
STEP 9: Connecting the Wire
STEP 10: Insulating the Glove
We have to now insulate our glove from inside near the finger to stop getting shock. This step is included after getting a good shock, its too necessary to insulate!! trust me!!, i used balloon rubber for this as its good insulator than cotton or air ,turn around the glove use some adhesive glue to place the balloon rubber, refer image for the area of insulation (mainly at the ends of the finger).
And here we have made it!! you have created your own self defense wearable gadget.Hope so i had explained so well that you have understood and can make one of your own!!
28 Comments
Samiksha Singh 7 years ago
Akanksha srivastava 7 years ago
ohoilett 8 years ago
Wow. Nice.
AVANISHP 8 years ago
kishanking 8 years ago
SamikshaS1 8 years ago
ÃķãšhŠ48 8 years ago
MritunjayS1 8 years ago
ryanjblajda 8 years ago
i would not recommend using this in a self defense scenario. but its still pretty cool.
RobinV12 8 years ago
aanwar6 8 years ago
aanwar6 8 years ago
it's so f***** cool man I already started making one for myself...
thanks to you I can easily do it ....
hats off bro ..
amazing work...
AnimeshS7 8 years ago
RohitR33 8 years ago
