Introduction: A Raspberry Pi Case Made From Scrap Wood
I made a scrap wood case for my Raspberry Pi!
Subscribe for great videos: https://www.youtube.com/channel/UC5-KZ_TpZ8_0Ko0xc...
Find more stuff on my website: http://innovativetom.com/
Twitter: https://twitter.com/innovativetom
Instagram: https://www.instagram.com/innovativetom/
Pinterest: https://www.pinterest.com/innovativetom/
Instructables: https://www.instructables.com/member/innovativetom...
Step 1: Laminating (glueing)
I used 3 pieces of scrap wood I had lying around. I glued and clamped them together so that they would be one piece.
I used way too much glue here. Next time I'll use less glue and it'll require less cleanup.
Step 2: Cutting to Sizes
I cut 4 peaces out of the larger block.
Each one was cut to a 1/2 inch.
Step 3: Slots for the Top and Bottom
I cut 1/4 inch deep slots into the top and bottom. For the plastic top and bottom.
Step 4: Cutting the 45s
The measurements of the sides don't really matter as long as both short sides and both long sides are equal.
Step 5: Cutting for the Panel Mount Connectors
I traced all the connectors.
Then used a combination of the chisel and dremel to make the holes.
RJ45 Male to Female Panel Mount 50cm: https://www.amazon.com/gp/product/B017N9XFR0/ref=as_li_tl?ie=UTF8&camp=1789&creative=9325&creativeASIN=B017N9XFR0&linkCode=as2&tag=innotom-20&linkId=24b2027c86cfa4c2746875f5568887fa
HDMI Penel Mount Cable 50cm:
https://www.amazon.com/gp/product/B00NL3DXC0/ref=as_li_tl?ie=UTF8&camp=1789&creative=9325&creativeASIN=B00NL3DXC0&linkCode=as2&tag=innotom-20&linkId=dff5742b672b45460cf6bd5c23801505
5 Pcs Panel Mount Rocker Switch:
https://www.amazon.com/gp/product/B00DUYSUAK/ref=as_li_tl?ie=UTF8&camp=1789&creative=9325&creativeASIN=B00DUYSUAK&linkCode=as2&tag=innotom-20&linkId=fa116a31e7427f9e91a828dc5a73d417
20" Micro USB Male to Micro USB Female:
https://www.amazon.com/gp/product/B012S0ZQNU/ref=as_li_tl?ie=UTF8&camp=1789&creative=9325&creativeASIN=B012S0ZQNU&linkCode=as2&tag=innotom-20&linkId=3c46c333b636bcc086c590698058d580
Step 6: Glueing the Box Up
Make sure you don't forget to put the top and bottom in like I did.
I used tape to hold all the sides together.
Step 7: Final Box Prep & Clear Coat
I cut the top off the box. I'm not sure if this is the best way to do it, so let me know if there is a better way.
I used hot glue to keep the plastic from sliding around. The plastic was from the bottom of an Aldis bag and was too thin for the 1/4 inch grove.
I put two clear coats of poly, sanding once in between.
Step 8: Finishing Up
I mounted all the connectors and screwed down the electronics.
I added some rgb LEDs and loaded retropi.
Check out the full video if you want to see more!
Check out https://youtu.be/i52UBhn4NWY if you want to see more of the RGB LEDs
