Introduction: A Raspberry Pi NAS That Really Look Like a NAS
Why a Raspberry Pi NAS
Well, I have been searching for a beautiful yet space saving Raspberry Pi NAS from the internet and I found nothing. I did find some NAS design with a Raspberry Pi get glued to a wooden based but that is not what I want. I want a real NAS. Those looks like professional and durable that can be used to store my massive amount of movie collections. So I decided to build myself a NAS from the ground up. Yes, you heard that. FROM THE GROUND UP.
In this project, I will not use any existing parts that is specially design for Raspberry Pi NAS. Instead, I will be using some common parts you can easily found on Amazon or ebay. So, lets get started!
By the way, that is my initial design sketch up there.
Step 1: 3D Modeling and Printing
After I have designed my NAS case in Autodesk Inventor, I test fit them to see if every joint is correctly designed.
Let me explains how the parts works. This case is divided into three parts. The left section is for the power management board and Raspberry Pi 3B+. You can use a Pi 3/ 2B+ as well as their footprint is the same. But you would want to use the Pi3B+ as it is faster. I will explain the detail later.
The right section of the case is design to hold two 5inch hard disk how swap mount (See picture 4). And the extra space at the back is for a 7 cm fan, a DC jack and the cabling.
Step 2: 3D Models Download (Case)
The 3D models can be downloaded here. License under:
Attribution-ShareAlike
CC BY-SA
Step 3: Printing and Assembling
After the prints has finished, we can start building the case.
The case is made up of three parts as mentioned before, you can attach them together with some M3x5 screws and M3x10 (for the top and bottom screw holes). Afterward, inserting the button caps into the holes and you will be ready for the electronic parts.
Step 4: Buttons and Signal LEDs
Actually the buttons and LEDs are some simple circuit that attach the signal from the Pi's GPIO to the front panel. There is nothing much special here except the button is a bit tricky. I would recommend you to do some test print before fitting the PCB inside the case with glues. That can make sure the quality of the buttons are good and clickable. In my design, as the RED LED require 5V, so I added a resistor on it and planned to directly connect the LED VCC pin to the power management board's 5V output. You can use the Raspberry Pi's 3.3V GPIO pin as well without the need for the extra resistor.
Step 5: Test Fitting
After receiving the hot plug bay from ebay, I placed two 2mm acrylic plate on the bottom and top of the right case. This is used to strengthen the support for the two HDD bay as HDD are kind of heavy after inserting into the bay.
Afterward, I used an old USB hard disk drive which, usually contain some kind of SATA to USB converter circuit board. For the one I bought, it come with a pre-soildered 12V input port that can support 12V power input for a 3.5 inch HDD. I attached them to the end of the two HDD hot plug bay and attached two cable to the end of it. One of the cable is a 2.1mm DC jack for the 12V input and the other one is a micro USB male cable for data and 5V. Both of them are special ordered so they bend in a direction towards the bottom and preserve space.
The finished product should look something like the picture 5.
Step 6: Tape and Glue
Now, we need to tape and glue the HDD hot plug bay into the case. First, I would recommend sticking a double sided tape on the metal bracket of the bay. After the bay is inserted and secured, put some superglue on the contact between the Acrylic plate and the metal bracket. But REMEMBER TO REMOVE THE PAPER ON THE ACRYLIC PLATE. I have forgotten to do so for the first time and I have a bad time moving everything out and do the same process again.
After finishing this process, you would not see two slot stick out of the right case and you can open then and close them via the handle build onto the hot plug bay.
Step 7: Test Fit
Now, stick your hard disk into the bay, and it should fit perfectly. (If not, you should ask for a refund from your seller of the hot plug bay xD)
You might notice that there are two rounded slot at the top back section of the right case. Those are for the USB cables. You can now stick the cables out and make it looks more tidy before start working on the electronics.
Step 8: Power Management Board
Here comes the power management board.
In the middle is a Tinduino. It is a self developed Arduino for low cost deploy and development from our Lab. Of course you can use an Arduino UNO for this and control the relay on off when there is a button press.
There are plenty of tutorials online which teach you how to make a board like this, for example:
https://www.instructables.com/id/Toggle-Switch-Wit...
It is basically a latch switch so you can do it in whatever style you want.
On the right is a buck converter. It steps down the voltage from 12V to 5V for the Pi and the Arduino.
And lastly, the bottom 3 port, from left to right is 12V power in, 12V power out for HDD1, 12V power out for HDD2
Step 9: Fixing Everything Together
Now, attach the power management board with the raspberry pi as shown in the picture above.
Plugin the 12V power input and everything should lights up (If not, maybe you can short the button and activate the Arduino Relay Toggle System)
Step 10: Close the Case and You Are Done!
Now, screw in all the screws, plug in the power cable and you are ready to go?
Not yet. We still need the software. But here is what the finishing hardware looks like.
As the software is still in development, I would recommend installing some open source OS / NAS system like the FreeNAS or open media vault. But I won't do that as I have planned to build my NAS from the ground up.
So what would I do next? Write my own NAS operating system!
Step 11: Install OS and Start Creating Your Own NAS Interface
Install the Raspbian Lite from the Raspberry pi website.
https://www.raspberrypi.org/downloads/raspbian/
and install it on your SD card. I think there are plenty of tutorial online so I don't duplicate those parts in this instructable.
Step 12: Move On? ArOZ Online System!
You might remember my post two years ago which is a Raspberry Pi media center system called
ArOZ Online (Alpha)
https://www.instructables.com/id/Simplest-Media-Ce...
Now, I have completely rewritten it into a brand new, DSM like Web UI called the ArOZ Online (Beta)
This system will works on both Window Host and Linux Host (of course Rasbian as well).
Step 13: Comming Soon!
Well, at least for now the system I wrote detects the 1TB drive I have inserted into the NAS.
So what next? The software still needs years of developments in order for it to run smoothly.
Currently, the max speed of transfer over 5G WiFi to HDD is around 100Mbps. Which is kind of OK for the fact that it is just a tiny little computer that is handing all your request. And it can reach around 93Mbps while transferring with Samba (Window SMB / Network Disk). This might be the advantage of using the Pi 3B+.
Please look forward to the update instructable to this project next year :))
======= April 2020 Updates ========
You can now get a copy of the semi-finished, custom written NAS OS with web desktop over here :)
51 Comments
1 year ago
Can you explain better how to build the power management board? I would like to make it but i don´t understand very well in the post. I would like to know the components to make it too.
Thank you so much.
4 years ago
Congratulations! Nice project I have only one concern speed of USB 2.0 on RPi3 :(
Reply 4 years ago
The USB 2.0 spec runs at 480 Mb/s, whereas the Wifi -G runs at about 450 Mb/s. Depending on the overhead, it should be able to keep up with Wifi speeds.
Reply 2 years ago
I attempted to make a NAS from the Raspberry Pi 3, and it was extremely flaky with RAID. It wasn't reliable or practical, so now I have a Pi 3 sitting around that I'm not sure what to do with.
The best idea I've come up with so far is using it for an emergency offsite backup (without RAID) to keep at my parents' house. This would supplement my Synology 4-bay NAS at home. I just have to figure out how to set up OpenMediaVault for offsite backup duties. (Are there any good guides out there for that? Is there any reason why this would be a bad idea?)
The Pi 4 seems much better suited for NAS use due to the USB 3.0 connections.
2 years ago on Step 13
Such a sweet looking webgui! Can you make it for a lighter webserver instead of apache? Most arm systems use nginx that will allow for much lighter memory usage
Also loving the 3D printed housing..very nice!
Reply 2 years ago
Hi! Thanks for your comment. I have recently switched from apache + php to Golang in the latest build of the webgui. You can find it over here : https://github.com/tobychui/arozos
3 years ago
Bonjour j'adore ton concept moi se qui m'intéresserai cest de savoit ou tu a acheter ton adaptateur sata usb. Merci d'avance.
Question 3 years ago
Hello, I´m also really interested in in raspberry pi 4 version.
It would be great.
3 years ago
very nice! can't wait for the finished OS. now that you have the design you should try to make this out of a sheet of aluminum. I would update for the Pi 4 though or add a board to give it usb 3.0
Reply 3 years ago
Hi, thanks for your comment. The OS is almost ready and after I can get my hands on a Pi 4, I will finish up the debug and testing process. (Raspberry Pi 4 is too hard to get at the moment, but I will see if I can get one soon :P ) Raspberry Pi 4 support will definitely be added soon, with its on board USB3.0 port and Gigabyte Ethernet, it is the best board to setup a Raspberry Pi NAS. I will also release a new instructable on this topic soon with improved casing and software. Please look forward to that :)))
Feel free to contact me at https://www.facebook.com/ImusLaboratory/ and keep yourself updated on the customized Raspberry Pi NAS OS.
Reply 3 years ago
Paitently awaiting on your updates. Have you considered maybe using a Banana Pro? it has sata, power and reset buttons and IR all on the baord.
Reply 3 years ago
I did consider of using Orange Pi instead of Raspberry or Banana (What a fruit basket xD) because of its faster CPU and ethernet port. In fact, the OS I am building can also be installed on boards that uses ARMv6l, v7 or ARM64 CPUs. If you got a Banana Pi and plenty of patients, feel free to contact us and join our on-going Beta testing :)
Reply 3 years ago
Might be easier to make it out of acrylic (Plexiglass) which can be purchased in sheets and laser cut (if you have access to a laser cutter). I was thinking something along these lines. Could be black, clear, transparent colors, basically any color you can find.
What's your idea? Do you have a layout in mind?
Reply 3 years ago
I do not have a laser cutter, but I would get my design like you on computer, and then lay it out on the plexiglass, you can then heat it up and bend it pretty easy. There are a few instructables on how to do it on here. As far as color, it might be cheaper to get the clear plexi and then scuff it up and paint it whatever you want. They even have glow in the dark colors or you can even add LED lights to it (if that is your thing, for my NAS simple and clean would be my choice though), but I do like the hole/grill look for the top for ventilation. I know that they are just hard drives, but I am a big fan (no pun intended) of cooling.
3 years ago
Cool build! I'm looking to do something similar. Surprised there are no commercial Raspberry Pi cases out there with room for drives.
Couple questions:
1. What is the largest dimension on your 3D print? That is to say, how big of a print area would one need to make the part with the largest footprint?
2. What did you print the enclosure with - PLA? ABS? Something else?
Reply 3 years ago
Thanks for the wait. I was quite busy a while ago and doesn't have time to check the Instructable comments. To answer your questions:
1. I don't kind of remember how big my printer's print bed was but I am quite sure it is a bit larger than a standard A4 paper but smaller than A3 with a rectangular shape instead of a square bed.
2. I printed it in PLA. I don't think my choice back then is good enough because the screws loose easily due to the soft plastic. Building the case out of Acrylic / harder material would be recommended.
3 years ago
Will you upgrade your design for the Pi 4?
Reply 3 years ago
Yes for sure, as soon as I can get my hand on one. :)
Question 4 years ago on Step 13
What the heck is "NAS?" I read your instructable twice, and am no closer to understanding what exactly you're trying to do.
Answer 4 years ago
Got it! Thanks Wikipedia!
NAS = Network Attached Storage.
RAID (see other comments) = Redundant Array of Independent Disks.
