Introduction: A SKATEBOARD
A skateboard which is belongs to Conan Edogawa.
Step 1: Making the Bottom Plate
Select two cubes in the shape generator to adjust to 45*20*1 and 5*20*1,
Select the round roof to rotate 90 degrees, adjust the radius to 10, the thickness is 1, copy this semicircle and rotate them
Step 2: Making a Non-slip Mat
Copy the left half of Figure 2 (yellow part), scale down to be 0.2 higher than the bottom plate
Combine the left half of the parts
Step 3: Single Tilt
Rotate the right half of the assembly vertically by 17° and combine all parts
Step 4: Made a Decoration
Place a rectangular parallelepiped as shown in Figure 4-1.
The components in Figure 3-2 are copied to be hollow, and the components in Figure 4-1 are placed as shown in Figure 4-2.
Copy a part of Figure 4-1 and place the parts obtained in Figure 4-2 as hollow as shown. Figure 4-4 Combine the components in Figure 4-3 to get 4-4
Copy the 4-4 graphic, as shown in Figure 4-5. Place a hollow cylinder and a hollow cube.
Combine 4-5 parts to get 4-6
Place 4-6 parts in hollow and 4-4 as shown and combine
Place a hollow cylinder on 4-7, the cylinder does not pass through the part
Combine 4-8 to get a round hole in 4-9
Select a sphere with a hollow cube as shown
Combine 4-10 to get 4-11
Align and combine the 4-11 and 4-9 round holes to get 4-12
Combine 4-12 with 3-2 to get 4-13
Step 5: Wheel
Choose a ring
Stretch the ring up to get 5-2 (the color is adjusted to black below)
Copy and paste 5-2 Choose a cylinder Select two multipoint cylinders in the shape generator
Combine the components in 5-3 to get 5-4
Select a meta capsule in the shape generator
Align 5-5 with 5-4 and combine to get 5-6
Choose a hexagonal body and a cylinder as shown in the figure to get 5-7
Align and combine 5-7 and 5-6 parts to get 5-8
Step 6: Wheel Set
Choose a cube length and width 4:3
Place four orange cylinders on the 6-1 squares (not tangent) Place four hollow columns respectively tangent to adjacent two cylinders (up and down and left and right symmetry)
Combine the hollow body of 6-2 with the red part (without the orange cylinder) to get 6-3
Place four hollow bodies to cut off the red part of the orange cylinder
Combine all the components in 6-4 to get 6-5
Choose a hexagonal body and a cylinder combination as shown
Copy 6-6 parts into four, align with 6-5 and combine to get 6-7
Place a cylinder in the center of the 6-7 assembly and combine to get 6-8
Combine 6-8 with 5-8 to get 6-9
Step 7: Finished Product Combination
Copy 6-9 vertically after copying
Combine with 4-13 to get 7-2 finished product
