Introduction: A Simple 5x7 NeoPixel Display
In the early 60's Hasbro took advantage of the growing interest in "computers" to sell a cleverly packaged trivia game called Think-a-Tron. Before you can begin to understand how Think-a-Tron works, you need to see it actually running. This video does a great job of explaining how to operate a Think-a-Tron.
I'm in the process of making a Think-a-Tron workalike. For more details about this project see: Think-a-Tron 2020.
This Instructable is about just one of the elements on the original Think-a-Tron that I wished to capture with some fidelity, the 5x7 "LED" display. I was surprised to learn that this display was purely mechanical! This was accomplished by shining a light trough a spinning disk (seen above) onto a 5x7 array of plastic lenses. It was a great effect. Very clever.
My 2020 implementation takes advantage of modern, individually-addressable, RGB color pixels. This is a pretty simple build so let's get started.
In addition to the printed parts you will need:
- BTF-LIGHTING 100pcs WS2812B Addressable 5050 Smart RGB LED Pixel Light on Black Heat Sink PCB Board for Arduino 5V DC - Amazon.ca
- Some 30 awg "wire wrapping" or similar wire.
- 4 M2 x 6mm bolts.
Step 1: Print the Parts
I printed the parts with the following settings (unless otherwise specified):
Print Resolution: .2 mm
Infill: 20%
Filament: AMZ3D PLA
Notes: No supports. Print the parts in their default orientation. To make a 5x7 NeoPixel Display you will need to print the following parts:
- 1 - LED Array Box
- 1 - LED Array Diffuser Note: It's all one piece, printed at .1 mm. I printed the black backing panel, paused the print at the 1.1 mm mark, then finished with some "transparent" PLA filament.
Step 2: Wire the 5x7 Panel
The panel on the original Think-a-Tron is 50 mm (2") wide and 70 mm (2 3/4") high and I wanted mine to be the same size. I searched for a suitably sized LED array but came up empty. I was about to start creating a custom PCB when I found some NeoPixel compatible, WS2812B addressable, smart RGB LED pixel lights. They are individual units but ship attached in a 10x10 grid as can be seen above. The good news for me is that each pixel light is about 10 mm in diameter which is perfect for my purposes.
With a little careful bending it was easy to snap off a 5x7 block of these. As shipped they are not connected so I had to wire the individual units in my 5x7 array together. I used some 30 awg "wire wrapping" wire that I had lying around from the old days ;-) It was a lot of pads to wire but not too hard. Use the second photo above as a wiring guide.
The pixel lights shipped with a three wire connector that I attached to the panel (photo 3).
Step 3: Assemble the Display
- Press the diffuser panel into the front of the display case with the "domes" facing forward.
- Place the LED panel behind the diffuser with the LED lights facing forward, and the wire leads aligned with the slot in the case.
- Use 4 M2 x 6 mm screws to attach the back of the display case.
Step 4: Test the Display
For testing purposes I connected the display to an Arduino Nano:
- Red wire to +5V
- Green wire to the D6 input
- White wire to GND
I wrote a short sketch using the Arduino FastLED library.
#include "FastLED.h"
#define NUM_LEDS 35
#define LEDS_PIN 6
CRGB leds[NUM_LEDS];
int A[35] = {0,0,1,1,1,1,1,
0,1,0,0,1,0,0,
1,0,0,0,1,0,0,
0,1,0,0,1,0,0,
0,0,1,1,1,1,1};
int B[35] = {1,1,1,1,1,1,1,
1,0,0,1,0,0,1,
1,0,0,1,0,0,1,
1,0,0,1,0,0,1,
0,1,1,0,1,1,0};
int C[35] = {0,1,1,1,1,1,0,
1,0,0,0,0,0,1,
1,0,0,0,0,0,1,
1,0,0,0,0,0,1,
0,1,0,0,0,1,0};
int T[35] = {1,0,0,0,0,0,0,
1,0,0,0,0,0,0,
1,1,1,1,1,1,1,
1,0,0,0,0,0,0,
1,0,0,0,0,0,0};
int F[35] = {1,1,1,1,1,1,1,
1,0,0,1,0,0,0,
1,0,0,1,0,0,0,
1,0,0,1,0,0,0,
1,0,0,0,0,0,0};
void setup() {
FastLED.addLeds<NEOPIXEL, LEDS_PIN>(leds, NUM_LEDS);
Serial.begin(115200);
Serial.println("5x7 LED Array");
FastLED.setBrightness(32);
for (int i = 0; i < NUM_LEDS; i++) {
leds[i] = CRGB::White;
FastLED.show();
delay (100);
leds[i] = CRGB::Black;
FastLED.show();
void loop() {
showLetter(A);
delay(1000);
showLetter(B);
delay(1000);
showLetter(C);
delay(1000);
showLetter(T);
delay(1000);
showLetter(F);
delay(1000);
showRandom();
void showLetter(int letter[]){
if (letter[i] == 1) {
} else {
FastLED.show();
void showRandom() {
for (int count = 0; count < 100; count++) {
if (random(3) == 0) {
leds[i] = CRGB::Blue;
} else {
FastLED.show();
delay(50);
And here is the 5x7 NeoPixel Display in action: Step 5: Final Thoughts
I have a pretty specific use for this Display, but I hope you see that the same techniques can be applied to any sized pixel array projects.
