Introduction: A Simple Solution to the Infamous Helping Hand's Problem
Recently , i bought one of those cheapy helping hands , and i started to note that the "hands " were wearing off , So i tried to found a clever ( and Cheap Of course ) Solution to this small problem
The Problem Is This : The Set Screw Was Crushing The Old Aligator Clips
And Guess what , ??
I FOUND The SOLUTION !!!111
And i decided to Publish This
And Guess what , ??
Step 1: Materials + Tools Needed
For The Proper Execution Of This Instructable You Will Need :
1 A Regular Skewer ( Bamboo Recommended)
2 Banana Plug Alligator Clips ( such as This Ones You Just Need 2 )
1 Piece of Heat Shrink Tubing ( at Least 1 inch long And 1/4 inch wide)
TOOLS
= Needle Nose Pliers
= Kitchen ( or similar ) Scissors or snips
= Ruler (Milimetric preferred (BTW 1 inch = 2.54 cm))
=A lighter
+ A Pen ( Not Shown)
Critical Working Gray Matter
And Of Course Your Old Helping Hands ( I forgot to Take A Pic ;) )
TOOLS
=A lighter
Step 2: Prepping the Alligator Clips
This is simple , just remove any insulation in the alligator clips
Dispose them properly .... if desired .
Step 3: Measure Once, Cut Twice
First Measure the part of the clip, that was protected by the insulation (Approximately 11 mm )
Write It (or memorize it ) down
Then cut two pieces of 11 mm of the Quarter inch HST
Step 4: Errrrr , Cut Four Times
Also Cut Two 11 mm Pieces of Skewer
TIP: Trace with ruler And Pen, Then Score them with the scissors and snap'Em with needle nose pliers)
Step 5: Improve the Alligator Clips
This Step Is Critical , Since the skewer will be the support of the alligator clip (thus , the set screw in the helping hands will not crush it )
Insert Each small piece in each Aligator clip
Then , Using Needle Nose Pliers , Apply a little pressure so the piece of skewer won't fall
Step 6: Collocate Heat Shrink Tubing
Just Slide the Tube in
Step 7: Heat Shrinking the Heat Shrink Tubng Using a Non-Heat Shrink Gun As Heat Source
I Made A Small video
You Don't Need to tell me , i know i took it too serious ...
Please Aovid To burn It ;)
Step 8: Re-assembling the Helping Hands
This Step is Easy Just Put All together Again
Follow The Pictures if necesary ,
Then Screw Again The Set-screws ,
Using A Little of Brute Force ,
But Taking Care Of Not Breaking It
Oh By the way , You're Done already
Step 9: Thanks for Watching
I Hope this instructable is helpful to you , I hope You enjoyed it
Feel Free to upload You comments , advices , Picture Or whatever you want ,
See ya!!
See ya!!
