Introduction: A Simple Transistor Based Electronic Siren
This circuit is designed as a simple replacement for the rare UM3561 / UM3562 siren ICs, utilizing only standard transistors, through-hole type resistors, and capacitors.
- C1 - 0.033μF Mylar capacitor - 1
- C2 - 2.2μF / 25V Electrolytic capacitor - 1
- C3 - 0.047μF Mylar capacitor - 1
- C4, C7 - 10μF / 25V Electrolytic capacitor - 2
- C5 - 0.1μF Mylar capacitor - 1
- C6 - 0.01μF Mylar capacitor - 1
- D1, D2 - 1N4148 diode (DO-35) - 2
- J1 - 2.54mm 2x3-Pin Header - 1
- J2, J3 - 2.54mm 2-Pin Header - 2
- Q1, Q2, Q6 - BC548 NPN transistor - 3
- Q3, Q4, Q5 - BC558 PNP transistor - 3
- R1 - 33KΩ 1/4W carbon film resistor - 1
- R2, R3 - 22KΩ 1/4W carbon film resistor - 2
- R4 - 2.2KΩ 1/4W carbon film resistor - 1
- R5 - 100KΩ 1/4W carbon film resistor - 1
- R6, R8 - 6.8KΩ 1/4W carbon film resistor - 2
- R7 - 150KΩ 1/4W carbon film resistor - 1
- R9, R10 - 10KΩ 1/4W carbon film resistor - 1
- RV1 - 500KΩ vertical trimpot (RM-065) - 1
- SPK1 - 16Ω - 32Ω Speaker - 1
- J1-CAP - 2.54mm Jumper Cap - 1
Step 1: Motivation
For some time, hobbyists have relied on dedicated sound generator ICs, such as the UM3561, UM3562 to build compact alarm and siren circuits. Unfortunately, this device is becoming increasingly difficult to find in the market. The manufacturer of the chip, United Microelectronics Corporation (UMC), is still around. However, they are no longer producing the UM3561 or UM3562. As part of a fun experiment, I decided to design a replacement circuit using only discrete transistors and passive components. This avoids the need for specialized ICs altogether. The result is a simple yet effective transistor-based siren. It can reproduce the familiar rising and falling alarm effects typically associated with police cars, fire trucks, or ambulances.
The design philosophy behind this project was straightforward: recreate the functionality of the classic two-timer based siren circuit (NE556/NE555 pair), but instead of timers or sound generator ICs, use only transistors in a multivibrator and modulation arrangement. By carefully selecting resistor and capacitor values, we were able to replicate the frequency modulation effect that gives sirens their distinctive sweeping tone.
Step 2: Circuit Overview
The circuit of this siren can be divided into three functional sections: the LF oscillator section, built around Q1 (BC548) and Q4 (BC558), which generates a slow modulation waveform. The rate of this oscillator, which controls how fast the siren "sweeps" up and down, can be adjusted via the 500K trim-pot (RV1). Capacitors C2 and C6, along with resistors R7 and R8, shape this low-frequency oscillation.
The next most crucial section is the audio frequency oscillator. Built around Q3 (BC558), this section is responsible for generating the actual audio tone. The output frequency is determined by the capacitor selected through jumper J1. By switching between C1, C3, and C5, different frequency ranges can be chosen, producing distinct siren effects. This is conceptually similar to selecting different alarm sound profiles on the UM3561.
The final section amplifies the modulated audio signal and drives a small speaker (16Ω - 32Ω). Diodes D1 and D2 provide bias stabilization for the push-pull transistor stage. This improves linearity and reduces distortion. The coupling capacitor C4 ensures that DC is blocked while allowing the audio signal to pass into the speaker.
Step 3: PCB
We gratefully acknowledge PCBWay’s sponsorship of this project. Their reliable PCB manufacturing, assembly, and 3D printing services make it easy to produce both prototypes and final products, ensuring consistent quality and reducing the risk of errors or durability issues. The PCB of this siren is available to order at the PCBWay website.
Gerber files to manufacture the PCB are available to download at PCBWay and project GitHub repository.
Step 4: Assembling
This circuit is designed to operate from a 6V to 12V DC power source. The recommended supply voltage is 9V. The output frequency of this siren is heavily dependent on the supply voltage. Therefore, to produce stable output, this circuit needs a regulated "clean" DC power source.
To make the project more accessible, we designed a dedicated PCB for this circuit. The board is compact and uses commonly available through-hole type components. For convenience, standard 2.54mm pin headers are provided for the speaker, power input, and jumper settings.
