Introduction: A Three Head Sprinkler for Odd Lawns
I think I achieved all of my stated goals with this project.
Step 1: Materials:
Step 2: Tools:
Miter saw (could also use a hacksaw or PVC cutter)
Sandpaper (for de-burring the cut pipe ends)
Utility knife
Adjustable wrench or pliers
Screwdriver
Step 3: Cut the Pipe:
Step 4: Dry Fit:
Step 5: Glue Up:
Step 6: Cut the Hose:
The spray heads are designed to throw water in a 15 foot radius. When the hose is connected and streched out, the spray heads will be about 15 feet apart. This will give good, even coverage.
Step 7: Thread Connections:
I have read that you really shouldn’t use Teflon tape on threaded PVC joints. The tape puts extra pressure on the threads that may cause the female fitting to fail over time. You should actually use pipe thread dope that is formulated for plastic threads. I found some at the hardware store next to the PVC primer and cement, but decided that the risk of failure of a threaded fitting in this system was low. More importantly, the effects of a failure would be a small puddle in the grass (as opposed to massive drywall damage, mildew, and other water-related issues if this was inside the home). I can live with that.
Wrap a short length of tape around the male threads, then screw into the female fitting. Use a wrench or pliers to snug it up. Be careful, you can strip the threads out if you really go crazy.
Step 8: Hose Connections:
When I started designing this project, I was going to use a PVC fitting that went from a garden hose threaded connector to a 3/4" slip fit. The hose would be cut to length with a garden hose threaded connector attached to each end. Then I priced out that option, and found that it was made of unobtainium, since it would have at least doubled the cost of the project.
