Introduction: A Vacuum Cleaner
Inspired by a link called “13 Exciting Weekend Projects for Engineers”, I was instantly drawn to a video that teaches me how to make a vacuum cleaner. It’s something I can use in my daily life and the materials needed are not complicated. For example, in the video, there are a lot of projects that require larger pieces of wood and sophisticated tools, it’s not practical to complete such projects within a short amount of time and even if I could, the final product will not be detail-oriented. With that being said, I wanted to shift my focus on making something creative, but at the same time, not extremely difficult.
- a tube – the thickness of the tube should fit the cork of the plastic bottle
- a plastic bottle – drill a hole at the bottom of the plastic bottle so that the motor can stuck in the center
- a motor – connected to the fan so that it creates enough pressure to suck up dust
- 3D print fan (with 8 blades) – go to onshape.com and build a mold for fans (try different shapes and different numbers for fan blades)
Step 1: 3D Print a Fan
- go to onshape.com and start a new project
- find a tutorial online and follow it through (make modifications based on the size of your bottle and the any other needed changes)
- combine all the parts you create into one piece (so it won't fall apart)
- print it out (make changes to the size, thickness, and the number of fan blades accordingly)
Step 2: Cut the Plastic Bottle
- prepare a (2L) plastic bottle
- use a knife or scissors to cut off the top part of the plastic bottle
- drill a hole at the bottom of the bottle (large enough for all the attaching wires to go through and for the motor to stuck at the bottom center of the bottle) -- do this step very carefully since the hole needed is relatively big and it takes patient to use the drilling machine
Step 3: Make the Nozzle
- stuck the tube through the bottleneck (make sure it stays)
Step 4: Power the Fan
- glue the motor and the printed fan together
- stick the motor at the bottom hole we cut through on the last step
Step 5: Bring Everything Together
- tape the top of the plastic bottle to the bottom half
- beautify the bottle the way you like it
