Introduction: Tin Can Art
I knew a real Tin Man, his name was Bobby Hansson. Not only did he write the definitive work on the tin can (The Fine Art of the Tin Can), but he was an accomplished photographer, sculptor, blacksmith, musician and maker of musical instruments; a true Renaissance Artist. He died in 2015. I wrote this 'ible a few years ago but have just now edited it to reflect Bobby's life in the past tense. Very sad to change the "is" to "was", the "know" to "knew", and I think of him every day still. To pay a bit of tribute for all the wonderful artwork and humor he has added to the world here is a Valentine appropriate in style to honor him, but easy enough for anyone to make something quite similar for someone they love.
Step 1: Supplies
- A variety of cans
- A frame or a bracelet
- Tins snips
- Cotter pins
- Gorilla glue, super and reguar
- Drill, drill bits
- A photo of your Valentine
- Some glass or plastic to put the photo behind
- Something to act as a heart, I used a cookie mold but anything at all may be used
- Plastic doll arms
- Folding ruler
Step 2: Pick a Can for the Body
Picking out a can that will be the body will help direct all the rest of your work. Make sure your body can has a lid, that is really important for attaching a head. The can should also have a bottom as this will make attaching the legs easier than without.
The size of the body will determine how big the legs will need to be, the face, arms, etc. But all bodies and body parts are very open to exaggeration. You can have really long arms or legs, every thing can be totally out of real proportion, your own eyes will guide you as we tend to see the human body in all sorts of things that are not even human.
Position whatever you are going to use for arms so you will know at what angle to cut holes or slits. You may put arms on one at a time with a rivet gun and rivets, or chose as I did to let the ruler stay in one piece to create stability.
Step 3: Arms
I used some folding rulers and doll hands for the arms, they were in proportion to the can I had picked out to be the body. I had the hands hold the heart and see where they need to be positioned to be able to do that, then cut the body can accordingly.
Step 4: Legs, Feet and a Base
It's trial and error to find cans that end up being the same height when stacked, you may end up just using some more ruler pieces. But whatever you use, try to make sure you end up with some feet, the feet can then be secured to a base and then your Valentine will look that much better and be more stable. An added plus to a base that is another tin can, is that you may fill it with rocks to weigh it down if your Valentine is a bit top heavy or prone to tipping over. The bottom tin can is also a great hiding place for money or jewelry.
Step 5: Attach the Legs to the Body
If this was a larger Valentine project I would use a rivet gun and rivets, but with such small tin cans you will easily get away with just using glue. I added some felt pads to give the top of the legs a surface to be glued to the bottom of the body tin can, but you may use cardboard or wood pieces from your ruler.
Felt pads will make things a tad wobbly if they are too thick, but if you need a bit of flex they are perfect, cardboard will create a stiffer "join".
Step 6: The Head
Chose a photo of your sweetie and encase it in something like a small picture frame, or cut out a head shape from some tin cans. I had a funny magnifier that fit well inside the bracelet I was using as a frame, as with all projects that are unique, you will use what you have on hand and it will end up being great.
I added a tin can to the back of the bracelet so I had a surface to glue Bobby's head to. I used Gorilla glue here as it expands as it drys and acts like caulk in that it fills up the whole area with expanded glue. I simply peeled off the dried glue that was in places I didn't want it to be seen.
Step 7: I Love Cotter Pins
They seem like a very forgotten fastener. I use them all the time though and just love them. In this case I drilled holes in the bracelet, then the lid of the body and inserted two cotter pins and that was that.
Step 8: Happy Valentines Day!
Put on your lid with the head attached and you are done, your sweetie will be thrilled. You could even put a treasure inside to be found when the head is lifted off. Chocolates? A ring? Post photos of what you have made and I will send you a patch.
32 Comments
11 years ago on Introduction
Hi Ninzerbean,
I'm taking a class here at Penland... tin art with Bobby Hanson, we were checking out instructables, and ran across your post.... It brought big smiles to the the class and Bobby in particular. Thank you for the awesome instructable and the beautiful inspiring piece!!!!
Reply 11 years ago on Introduction
Wonderful, thank you for letting me know! Enjoy your class too.
Looking at it again, and still think it's fabulous!!!
YOU are fabulous! Everywhere I go around this site I run into your positive comments. Thank you.
Thanks Sweetie! Right back at 'cha!!
xxoo Lynie-Poo
BTW,
would you like me to send you a copy of my book?
I would love one but you mustn't. I have no little kids in my life to share it with. Thank you though.
12 years ago on Introduction
So freaking cool!
Reply 12 years ago on Introduction
Thanks a freaking lot!
This is stunning. I always enjoy your work but this really shows your aesthetic bent. This is also known as Assemblage Art and some of it's practitioners can be found here http://en.wikipedia.org/wiki/Assemblage_(art) . I appreciate this type of art a great deal and I have a great deal of respect for it. I find it quite difficult to make appropriate/artful selections of materials,
Thanks for the hint on the felt glue pads. I've struggled with that before but not anymore 8-D
BTW I like the instructions and arrows on the images. New? I don't remember noticing that.
Mine is a "Two Uses" family and so one of the biggest issues I have is with packaging and containers. They usually are a one shot product. I'd like to see an Instructables section dedicated to reuse and adaptation of packaging and this piece is a great example of why.
Again just beautiful and so evocative of Early Americana
Thanks,
Marcintosh
Wow, thank you so much for such a wonderful compliment. I have been reluctant before to make unique pieces for Instructables because I want to everyone to easily be able to replicate what I make, but I think there is enough technique in this one to be applicable to what people have on hand.
I got into the habit of using arrows because up until a short time ago my computer and browser wouldn't let me make little yellow boxes.
When I was little I used caps from toothpaste tubes for drinking cups for my trolls, so I guess the idea of using trash for something else was always in me. Being that I collect cans to use in making other things, I found that the collection was starting to own me; the cans became too precious to turn into something else. It only took my sorting through a lifetime (97 years) of my grandmother's things to realize that you can't take it with you and it's a burden to those you leave behind because the mere fact that you owned it makes it too precious to throw out. So, making the stuff into things that the next generation would actually want to keep, frees you to cut into the "precious" object that is just a part of a collection that only means anything to you. Sorry for such a long reply here, I feel like I am just waking up to this fact and I have to start making many more things.
There is a recycle or reuse channel on Instructables, it's under "Living" I think. But you are right, a category or section on the topic would be great. Your phrase "two use" is really great and it makes me think right away of your great "ible with the bottles that water the plants.
This is so very clever...and a wonderful addition to all the other fantastic creations you come up with...what a great inspiration for everyone! IASPOY !!
You've done it again, NB! Incredibly creative, your imagination astounds me, continually...thanks for posting your wonderful art-work! Cman
Thank you for your always-positive feedback, and complimenting ME about my imagination is so funny coming from YOU.
That looks really cool, nicely done!
Thank you!
Exxxxxxxxxxxxxxxcellent! I have a stash of things I plan to use for a creation-you beat me to it-and wow is it ever amazing!!!!!
Great! I want to see when you are done - and thank you!
Amazing! I just love it.
Thank you! That is so great.
Sure! That's no problem. I absolutely love your work.
