Introduction: A Wonderful Ribbon and Plastic Basket
When I first saw this basket at my local craft store,
Step 1:
it looked like this. They were just setting them out. It brought back memories of my Mom. When I was a child, back in the 50’s and 60’s, my Mom had a plastic basket like this! It was brown, and the holes were larger (around 1 inch) and I watched her weave fabric in and out of the holes to make it a solid bag to hold her yarn in for crocheting and knitting etc. I realize that what I remembered was my Mom crafting, and I wanted it. I thought I could wait. I lasted 24 hours. (Maybe I’ll make one for my Mom.) This is how I made a good basket, wonderful! Here we go.
Step 2:
Supplies:
A plastic basket ($3 @ HL, in three colors)
30 feet of 3/8” or 7/16” ribbon (choose colors that go with your basket- I used 3 colors and so I had three bolts - it took +/- 3 feet for each round)
White glue
Paper clips
Scissors
White glue
Paper clips
Scissors
Step 3:
I chose to weave the ribbon through the holes directly off the bolt of ribbon, starting at the bottom row. I chose some white ribbon I already had, and the peach I already had and bought the brown when I realized I wouldn’t have enough peach. I started on one of the basket ends weaving in and out
Step 4:
until I reached the beginning. I cut an overlap of about ½ - 1 inch. I put a large drop of glue on the ribbon
Step 5:
and then used a paper clip to hold the two glued pieces together until they are dry.
Step 6:
For the next row up, I started at the opposite end because I didn’t want to crowd the paper clips. I choose the peach ribbon for this row. I made sure to offset it so it would look like weaving. Again I went all the way around, over lapped, glued and paper clipped it.
Step 7:
I kept going, alternating colors as I choose, until I reached the top row. This row, I took what was left of the peach ribbon and started in the middle back of the basket with the middle of the ribbon,
Step 8:
and worked around both ends until I reached the middle front. Then I tied a bow.
Step 9:
You know how to tie a straight bow, don’t you? You tie like you do for a square knot. Tie the base part with the “left” ribbon over “right” ribbon,
Step 10:
down, under and up.
Step 11:
Pull tight.
Step 12:
Then make a loop in the left ribbon,
Step 13:
and take the right ribbon and take it over the left loop,
Step 14:
down, under and up forming the second loop.
Step 15:
Pull tight. So all you have to remember is “left over right, right over left”.
I’m glad you already knew that.
Step 16:
Once all the glue is dry, remove the paper clips and tuck in any ends.
Step 17:
I have a major yarn project for this year and this basket will be the home base for my yarn. It makes me smile, almost as much as Instructables does. Enjoy!
