Introduction: A Wooden Dog
I will show you how to make a cute wooden dog :)
Material
Wood. I used a 2 cm × 16 cm × 10 cm piece of beech wood, but any wood is fine. If you do not have many woodworking tools at your disposal, you should use softer wood, for example fir.
Tools
- * Pencil
- Glue
- * Saw
- * Sandpaper (60 grit, 120-180 grit for finish)
- Belt sander
- Drill + wood drill bits (I used a 6 mm one)
- Rasps and/or files
- Vice
* The project can be completed with only pencil, saw, and sandpaper. With these an appropriate wood should be used.
Step 1: Concept
Draw a dog on a paper or on a piece of wood directly. If you draw it on paper, you need to glue it to the wood.
I prepared the design which you can download and print. If you are going to use drill to roughly shape the dog, my drawing has additional lines to guide you. (So you do not drill or saw too close to the main piece)
Step 2: Transfer the Outline on the Wood
Draw or glue the dog on the wood. I used wood glue and waited over the night to dry. Make sure that the wood grain goes vertically, otherwise the legs and tail will not be sturdy.
If you will use the glue, make sure you spread the glue as evenly as possible.
Step 3: Rough Outline
I found that drilling is the easiest way to cut through hard wood. Of course you can use saw or any other tool to cut the piece to its rough dimensions.
With a sharp object mark where the center of the drill should go. A nail will do the trick. Put another piece of wood between the table and the dog, so you will not damage the table. Carefully drill around the dog. Pay attention so you do not drill too close to the main outline. Also, if you drill too close to another hole, the drill may slip to the other hole and extracting the piece will be harder.
Once you come around the piece, take a saw and separate the it from the wood. When I saw this roughly shaped dog, I decided to name it Spike :)
Step 4: Fine Outline
With a rasp, file, or sandpaper carefully approach the main line. At this step the shape should be good but does not need to be perfect. In next steps we will eliminate the mistakes we made until this point.
Step 5: Legs
Drill a hole where the legs will be separated. And try not to lauhg doing so :)
With a saw cut between its legs towards the hole. Then sand the inside with a sandpaper until it looks nice.
Step 6: Tail, Head, and Ears
I used a beltgrinder to thin the tail down, because it removes a lot of material quickly. In the picture, where the paper is still there, we can see the area I sanded. I also sanded around the neck so the ears pop out. I thinned down the nose area which completed the ears. To fully form the head, I narrowed it towards the nose.
Step 7: Final Sanding
Now the game of patience begins. Sand down all of the edges. At first I used quite a rough sandpaper (60 grit) around the body of a dog. There was the most of the material that had to be removed.
Then I used a finer sandpaper (100 grit) to refine the shape even further. At this stage I sanded the whole dog, not just the body.
I rounded the legs with a thin strip of sanding paper. I put it around a leg and sanded with movement that you see it when they polish shoes in movies.
Finally, with the finest sandpaper I had (180 grit), I removed all scratch marks I made using rougher sandpapers. The more time you take for this step, the nicer the final product will be.
Step 8: Done
The dog is finished, the picture shows the final result.
I hope you enjoyed the project! :)
Sculpting Challenge
10 Comments
1 year ago
Go bye
1 year ago
I am at wood work right now ok
1 year ago
I will talk you later ok I will talk to you guys at playtime ok
1 year ago
Do you guys what to be friends?
1 year ago
I am built a wooden dog today
1 year ago
What up guys
1 year ago
Hi I love puppies and I love dogs too
1 year ago
good job onm makeing this :)
2 years ago
i love dogs
2 years ago
Fantastic results, well done! : )
