Introduction: A Simple Infrared (IR) Detector
This is my first Instructables hope so it would be good
We are gonna make a simple IR detector ....
Step 1: Materials You Need...
1) a breadboard
2) a red LED
3) 2 X 1.5v AA batterys
4) A battery holder
5) wires
6) sissors
7) solder gun
8) wire cutter
9) solder wire
10) a switch { if needed as i have not used }
11) a TSOP 1838 IR reciver
12) any IR remote
Step 2: Circuit Diagram ...
TSOP 1838 pinout :-
pin 1 = + VCC
pin 2 = - Gnd
pin 3 = output
Keep in mind you need ONLY 3V as input not more than that....
Step 3: Start Now...
Solder the wires on the battery holder
red wire for positive
and yellow wire for negative { you can also use black wire }
Step 4: SOLDERING...
Solder the TSOP 1838 on to the board carefully and cut it's legs
Step 5: LED....
Now solder the red LED on to the board ..
such as +ive of LED connected to the pin 1 of the TSOP 1838
& -ive of LED connected to the pin 3 of TSOP 1838
Now connect +ive of the battery to the pin 1 of TSOP where +ive of LED is connected ...
Now solder -ive of battery to the pin 2 of TSOP
Step 6: Insert Batterys.....
Step 7: YOU HAVE DONE IT !!!
Take your IR remote and press any key on it, the LED will flash as per the signal transmitted by the IR remote
