Introduction: A Stronger Mini-u Bike Holder
Here is my first instructables.
I recently purchased a mini-u bike lock, very handy, compact, but supplied with a poor holder.
I decided to replace this bike holder. Here is the result.
Step 1: The Original One
The original u-bike holder does not fit into my frame and it is impossible to tighten it around the seat post.
Step 2: Looking for Replacement
I found an evacuation pipe. The mini-U fits into it perfectly. I cutted the exact length of the orange part of the mini-U.
Step 3: Let's Transform the Pipe
I've made 3 consecutives adjustements, in order to install the pipe under the saddle, with cable tie.
The first one, I cutted the half extremity of the pipe.
Then , I drilled a hole.
And then, at the opposite of the hole, I've made a little notch. The cable tie will fit into this notch. The pipe won't slip off the cable tie.
Step 4: The Amazing Cable Ties
God bless the inventor of cable ties. What wonderfull things I can do with it !
I used two huge cable ties, a specific tool is needed to tighten cable ties (by hand it' impossible !)
Step 5: Installing the Mini-U Lock
First, I put the straight part into the pipe.
Then I install the U part.
Thanks to the specific saddle shape, I'm able to lock the mini-U with its key ( Not so many room).
Step 6: Conclusion
I hope you enjoyed my little bidouille (it means hack in french !)
Sorry for my english, I try every day to speak better and better (it's so difficult).
I think it's possible to use a longer pipe, when the saddle has got a different shape.
