Introduction: A Survival Kit for Both Urban and Wilderness
Step 1: Okay, So Now This Is What I Have in Mine.
2. 1 emergency Poncho- Everyone needs one. Keeps you dry during rain.
3. Emergency Blanket- Can keep you warm because it reflects your body heat back at you. Plus it makes a great signal if your lost and need to be found.
4. some shoe string- This has many applications, as i will demonstrate in my video's i'll be making when the weather gets better.
5. slingshot repair kit- Obviously, to repair my slingshot when it get's broken.
6. 300 lb test travel hammock- this is for relaxing and sleeping. But if you don't have a tarp or tent, you can also use this to collect rain water or just drape it over yourself in the rain if you don't need the water at that point in time.
7. Multitool knife with pliers- use this for just about everything from setting traps to repairs and anything else you can think of.
8. Solar/crank powered radio with weather stations, AM/FM radio, and Built in flashlight.- this is good for if your lost or trapped somewhere or when the electricity goes out. It runs strictly on Solar power and Crank powered. Mine has a built in flashlight, AM/FM radio with weather stations, and can also charge cell phones that have small USB cords.
9. Butt Plug- The name sounds funny, but it actually has a good use. When hunting, you use this with large kills (deers, elks, bears, etc.) this goes in the rectum and after twisting it around a couple of times to grab ahold of it from the inside, you pull out the rectum, tie it off, and cut it off. This makes cleaning the dear more sanitary and easier.
10. Matches and Fishing hooks- Matches are used to start fires and other small things. I have mine in a matchstick case that has a built in flint bar on the bottom. The fishing hooks are random and range from small hooks to larger ones for bigger fish like bass and similar. You can hold them in an empty pill bottle.
11. Filet Knife-Used for cleaning and filleting fish. Mine has a built in line Cutter for when my fishing line gets stuck, as well as a built in hook and knife sharpener on the side.
Step 2:
12. Binoculars- These things come in handy for just about everything. use them to see animals, landmarks, people, places, etc.
13. Magnesium and flint- this is good to have if you don't have matches. Just scrape of some magnesium (about a dime amount will do) strike the flint with a knife to create a spark, then add some kindling and you got fire.
14. Compass and Hobo tool- Compass is used for navigation. Mine has built in whistle, lens, and thermometer. The Hobo Tool is your eating utinsels in swiss army knife form. It comes complete with knife, fork, spoon, cork screw, and divet. It also comes apart into two pieces so you can use the knife and fork at the same time.
15. Cleaning Knife- this is used for cleaning animals. mine has a built in slicer that skins it just deep enough without wasting meat.
16. Slingshot ammo Pouch with ammo- a convinient pouch that holds ammo for BB guns, slingshot's, and other small things. I also have 250 shots for my slingshot.
17. Hip Pouch- Hip pouches are good for carrying small items for when you don't need to be burdened with everything all at once. This is good to hold your fishing kit, matches, compass, and any other small items you might need in a hip pouch.
Step 3:
19. State Map and marker- It's always good to have a state map of your state. It helps you know where you are if your in an unfamiliar place, and it's good to know where to go. (Note: while not necassary, it's good to get a laminated one because you can use a washable marker on it to mark it and wash it off.)
20. Map Compass- Map compasses are good for when your trekking cross country, not necessary from one city to another. This is perfect for wilderness maps, city maps, and similar.
21. Slingshot- while the primary use of this is as a weapon, it can also be used in hunting, or distractions if there is anyone/thing unfriendly around you. However, you can also use this for signaling others in your party if your in a group.
22. Duct tape- Where do you start on how to use duct tape in a survival kit? Ductape has so many uses, it should be standard for all kits. Repairs, markers, anything can be used with duct tape.
23 Camping Saw- use this to cut your logs in to smaller logs for fires, or to mark trees, or to cut off limbs, or anything else. (Note: While i don't think it would be necessary, it can also make a weapon against unfriendly animals and people. I don't suggest using this as a weapon unless it is absolutely necessary to survive.)
Step 4:
24. How to Stay Alive In the Woods book- This book is essential in surviving out in the wilderness. It has many entries that will help you find food, make fire, make shelter, stay found, and medicines you can find in nature. A MUST HAVE!!!
25. Crowbar/ Wonder Bar and Mallet- The wonderbar has many uses, some of which include opening doors in abandon buildings (IN SURVIVAL SITUATIONS ONLY!) as a weapon, and even as a make shift grappling hook. The mallet is obviously used for hammering things, but can also be used as a weapon or as part of a trap.
26. Belt- this is good for not only holding your pants up, but you can use this to help you climb trees or similar if you dont have rope/ grappling hook. It can also be used to hold onto your knives and other things that clip onto your belt for easy access.
27. Fire Starter (kindle)- This is good for starting a fire or keeping fire going when fuel is scarce.
Step 5:
29. 50'- 100' feet of rope (300 lb test)- rope, like duct tape, is universal. use it to climb things, hold things to tree's, fix up your tarp, or drag things behind you.
30. Sharpening Stone- This is used for keeping your knives sharp all the time. (Recommendation: Get one that has a coarse side and a soft side.)
Now, this is what i have in my kit. I only consider some things in this kit to be standard in all kits. Each kit should be designed for each individual's particular needs. Some kits have more water based things for those who live near water while others are based on water use for dry areas. But as i've said before, this kit is for those who don't know if they want to stay in the city or go to the forest.
Please note not everything i have in my kit is shown due to size.
For example, my first aid kit is really big, so i cant carry it in my kit. That doesn't mean that a small one wont help just as much. It is up to you.
Remember, in survival, the important things you'll need is to keep a cool head, stay safe, and be prepared.
If you enjoy my kit, subscribe to my account and keep an eye out for my videos where i show you how to survive in various conditions. (note: due to my video camera's lack of water protection, I will not be demonstrating in rain or snow.)
