Introduction: A10-02 Knex Gun
This is a modified version of someone else`s gun i just really like it so i made it 3-D and shared
Step 1: The Barrel
Before you begin assembly collect 27 snowflakes, 1 orange double sided connector, one green rod, 2 grey rods and one white rod. you may now begin assembly take 15 snowflakes and put them on the 2 grey rods like in the picture. then you take the orange double sided connector and put the white rod into one end this is your trigger now take your newly assembled trigger and slide it on the right side of the snowflake covered grey rods then put the rest of the snow flakes on and the green rod like in the picture. put it aside until final assembly
Step 2: The Handle
Before you begin assembly collect 8 grey one sided connectors, 3 yellow rods, and 3 orange double sided connectors. you may now begin assembly first take the 3 yellow rods and line them up then slide 1 orange double sided connector all the way to the top then take 4 grey one sided connectors and slide them on like in the picture then slide the next double sided orange connector up to the middle then put the other 4 grey one sided connectors on like in the picture then your last orange double sided connector on the end. put it aside until final assembly.
Step 3: The Firing Pin
before you begin assembly collect 1 grey rod, 1 orange double sided connector, and duct tape. first take your grey rod and put the orange double sided connector on the end then tape the joint
Step 4: Final Assembly
before you begin collect the barrel, the handle, and the firing pin. you may now begin final assembly first take the handle and slide it on the bottom of the barrel to a comfortable distance from the trigger. then slide the firing pin into the butt of the barrel then add 2 rubber bands to the top and 2 the the bottom and your done
