Introduction: AA & AAA Battery Sorter / Dispenser
AAA & AA battery sorter / dispenser
- This battery dispenser automatically sorts AA and AAA batteries
- Single piece. assembly work is not necessary
- Easy to print. It does not require support structure
note: when the dispenser is empty, the first battery sometimes pops out from the bottom outlet. The batteries sometimes jam in the storage. For the simplicity and print easiness, these limitations remain in current model.
This model consists of a single piece. No parts other than 3D printed object is necessary.
Step 1: Print
- Print the model as supplied posture.
- Do not use support structure. If some supports are generated in the structure, it is very hard to remove. All overhangs are slanted inside and out, and it does not require the supports.
And you are all set! Insert AA and AAA batteries from the hole on the right side.
