Introduction: Simple ABB PLC Program- Academic Project
This is simple project which aim to program using CoDesys software with Ladder Diagram(LD) language.And please notice that is not a tutorial project, share your knowledge and comment with me.
The project contains with these functions..,
Filling process
Capping Process
Label Process
Carrier Process
Releasing Process
Sample product
Auto/Manual
Above functions will be explained with next steps.
Step 1: Programmable Logic Controller (PLC) and Codesys Software
A programmable logic controller (PLC), or programmable controller is an industrial digital computer for the control of manufacturing processes, such as assembly lines, or robotic devices, or any activity that requires high reliability control and ease of programming and process fault diagnosis.
Codesys Software
CODESYS is a development environment for programming controller applications according to the international industrial standard.
Step 2: Inputs Addresses
The machine inputs..,
Start - START
Stop - STOP
Auto - AUTO
Manual - MANUAL
Position Sensor 1 - S1
Position Sensor 2 - S2
Position Sensor 3 - S3
Position Sensor 4 - S4
Position Sensor 5 - S5
Position Sensor 6 -S6
Position Sensor 7 - S7
Position Sensor 8 - S8
Position Sensor 9 - S9
Manual Conveyor Belt - MANUAL_CONVEYOR_BELT
Manual Filling - MANUAL_FILLING
Manual Capping - MANUAL_CAPPING
Manual Label - MANUAL_LABEL
Manual Carrier Arm - MANUAL_CARRIER_ARM
Manual Arm Forward - MANUAL_ARM_FORWARD
Manual Arm Reverse - MANUAL_ARM_REVERSE
Manual Arm Release - MANUAL_ARM_RELEASE
Sample - SAMPLE
Step 3: Output Addresses
The machine outputs..,
Conveyor Belt - CONVEYOR_BELT
Filling Arm Down - FILL_DOWN
Filling Process - FILL_FILLING
Filling Arm Up - CAP_UP
Capping Arm Down - CAP_DOWN
Capping process - CAP_CAPPING
Capping Arm Up - CAP_UP
Label Arm Down - LABEL_DOWN
Label Paste Process - LABEL_LABEL
Label Arm Up - LABEL_UP
Arm Forward - ARM_FORWARD
Arm Reverse - ARM_REVERSE
Machine process arm Down - MACHINE_CARRY_DOWN
Machine process arm Open - MACHINE_CARRY_OPEN
Machine process arm Close - MACHINE_CARRY_CLOSE
Machine process arm Up - MACHINE_CARRY_UP
Step 4: Conveyor Belt Process
When the machine is Auto mode,
When a bottle is seen in front of the sensor number 1 (S1), Conveyor Belt starts to rotates until Position Sensor 3 (S3).
sensor number 2 is used to set the packing process.
Step 5: Filling Process
When bottle comes to Position Sensor 3 (S3),Conveyor Belt is going to stop and Filling process will be started.
There are three steps..,
Arm moves down,three seconds.
Filling process,three seconds.
Arm moves up,three seconds.
I used three seconds for each cases with different timers.Totally nine seconds for filling process.
After complete the filling process,Conveyor belt will be started to rotate for next position that is Capping process.
Step 6: Capping Process
Position Sensor 4 (S4) is used to operate the Capping process.When sensor detected the bottle,Belt will be stopped and arm will be activated.
There are also three steps with different timings..,
Capping process,two seconds.
Step 7: Label Process
When bottle comes to Position Sensor 5 (S5),Conveyor Belt will get stop and Label process will get start.
This process has three steps..,
Arm moves down,two seconds.
Arm moves up,two seconds.
Step 8: Carrier and Release Process
Conveyor Belt will get stop and Carrier process will get start.
This process has four steps..,
Arm grip open for two seconds.
Arm moves down for three seconds.
Arm grip carry the bottle for two seconds.
Arm moves up for three seconds.
Next step is releasing the bottle.Arm moves to last position.There are two boxes those are packing and sample,arm has to choose right box.it will be chosen according to the beginning conditions.Mentioned those conditions bellow.
If sample switch and Position Sensor 9 (S9) are activated,Arm will release the bottle at Sample box.
If Position Sensor 2 (S2) and Position Sensor 8 (S8) are activated arm will release the bottle at packing box.
After complete the process,Arm will start to move back until Position Sensor 7 (S7).Then setup will get reset for next bottle.
These three functions those are Carrier,Packing and Releasing are happening in same arm.For represent in visualization,I used separate polygons and memories for the program.
Step 9: Auto and Manual
The project available Auto mode and Manual Mode.Firstly the mode should be selected .Auto system works as usual.There are separate switches for Manual.
Step 10: Visualization and Representation
I represented machine status and system status using polygons.
Step 11: Conveyor Belt
When Conveyor belt is running,color is red.
Step 12: Filling,Capping and Label
Down arrows are represented,arms moving down.
Up arrows are represented,arms moving up.
Bellow parts are about Filling,Capping and Label visualization.
Step 13: Carrier and Release
Carrier :-
First part is represented about carry grip opening.
Bellow part is represented about carrying.
Release :-
Last part is represented about releasing.
Third part is represented about close the grip.
Arm Forward and Arm Reverse are represented by arm moving.
Step 14: Control Panel and Switch Board
There are Start,Stop,Sample,Auto,Manual in switch board.
Manual control panel has eight switches.
Step 15: Packing Box and Sample Box
Step 16: Finishing and Testing
Step 17: Codes and Testing Video
There is the video with simple visualization.
