Introduction: AC MOTOR ROTATION CONTROL
About: designer of circuits and professional electronic projects www.pcbway.com
We will carry out an AC motor rotation inversion control project by means of a push button.
Step 1: SCHEMATIC DIAGRAM
We have done this project in the easyeda software, the schematic diagram of this project is with all its values ​​so that one can do it yourself, it integrates a switched source called TDPOWER of 5VDC for the control stage.
Step 2: FUNCTIONING
First, we will understand the operation of the project. We energize the circuit with 220VAC, which in turn will work on the same card with the motor capacitor and the AC220V motor.
and integrates a 5VDC TDPOWER source for the control stage.
In the control we will have an up and down button integrated in it, so we will activate it to go up and down, said by the way, we have limit switches normally closed, so when it reaches the limit, do not activate it anymore, this allows me to know the limit of the motor.
In the project I have used PC817 optocouplers this allows me to isolate the control stage with the power stage so I have better use and there will be no interference with both stages and I protect both the input and output from any short circuit damage.
And finally we will have to see how much load my RELAY supports. In this case, it supports a maximum voltage of 250VAC and 10A, so this project is designed for it..
Step 3: Relay
5VDC Relay - Max Capacity 250VAC / 30VDC - 10A, widely used in the control of high voltage and/or high amperage components, such as light bulbs, water pumps, solenoids, motors, solenoid valves, water heaters, among others, which do not They can be directly driven by a logic gate, microcontroller, and Arduino or Raspberry PI development boards. In these cases it is necessary to use a Relay or also called Relay. These devices allow high voltage loads to be controlled with a small signal.
The Relay with 5VDC activation in its coil can handle loads up to 250VAC at 10A. Its small size makes it ideal for designs where size is important. To connect this Relay with the control stage, it is necessary to use an intermediate Driver between the control stage and the power stage (Relay). The driver can be a 2N2222A transistor, a 4.7 KΩ resistor and a 1N4007 diode in FlyBack mode in parallel with the Relay coil.
Main features:
Coil Operating Voltage: 5VDC
Coil current: 90mA
Maximum charging voltage: 250VAC / 30VDC
Maximum charging current: 10A
Contacts: Common, Normally Open (NO), Normally Closed (NC)
Action time: 5ms~10ms
Step 4: ELECTRONIC COMPONENTS
  • 1 TDPOWER 220VAC/5VDC
  • 2 PC817
  • 2 RESISTORS 10K 1206
  • 2 RESISTORS 220ohm 1206
  • 2 RESISTORS 1K 1206
  • 2 LED 0805 GREEN
  • 2 DIODES 1N4148W SMD
  • 2 TRANSISTORES BT3904 NPN SMD
  • 2 BLOCK TERMINAL BLUE 2 PIN
  • 1 BLOCK TERMINAL BLUE 3 PIN
  • 1 CONECTOR 4 PIN
  • 1 CONECTOR 3 PIN
  • 2 RELAY 5VDC
  • 1 PCB
Step 5: PCB CHARACTERISTICS
  • VIN 220VAC
  • REGULATOR 5VDC
  • I MAX 100mA
  • EFFICIENT AC MOTOR CONTROL
  • ISOLATED STAGE OF CONTROL AND POWER STAGE
Step 6: EASYEDA
This project was made in the Easyeda software as we can see the tracks and the 3D image of the project working perfectly are no difficulty
Step 7: PCBWay
PCBWAY has 10 years in the electronics industry manufacturing professional PCBs, assembling PCBs managing to satisfy the demands of all parts of the world, in addition to meeting the highest quality and delivery time standards. PCBWAY allows the manufacture of your PCBs from 5 units.
This project was carried out thanks to PCBWAY, a company dedicated to the manufacture of prototypes and professional PCBs, in addition to offering you a ready assembly service with all the components in your PCBS, complying with the established quality and delivery time standards.
We thank PCBWAY, a leading company for manufacturing and assembling professional PCBs with the highest quality, PCBWAY has fair reasonable prices, punctual shipping time and 24-hour customer service, it also offers you the option of quoting all its services in his web page. Do not think twice and start manufacturing your professional PCBs from 5 units safely.
10pcbs at $5 order them here www.pcbway.com
We thank PCBWAY for the professional pcb they provide us for this project.
GERBER PCB:
https://mega.nz/file/3BwwSRLb#KHKRoG35k5yK85ad24930mOaNe57KCeEExIuNlZyOK8
