ACCESSING ARIAG25 FROM ANYWHERE IN THE WORLD
Intro: ACCESSING ARIAG25 FROM ANYWHERE IN THE WORLD
ACME SYSTEMS
We design and manufacture in Italy Linux embedded boards since 2005. Our main business is to create hi-quality CPU Linux modules designed for the professional market with long term availability, high reliability, low power, low EMI at right cost.
WEAVED
The Weaved fabric for the Internet of Things for Everyone provides secure, private connections to devices across the internet and from mobile devices.
I will explain how you can access your ARIAG25 from anywhere in the world in minutes, using HTTP service.
Problem
Normally, when you use the ARIAG25 as web server, tests are done using the LAN network. When you want to test from the WAN, you normally have to config your router (NAT/DMZ) to accept outside access. If you are familiar with your router, this is not a problem, but imagine dozens of other routers models where you need to know each one or need to know the NET access rights? Maybe it will be headache for you.
The solution
To solve these need, here some steps:
STEP 1: Create a INTERNET CLOUD Account on WEAVED
Enter in developer.weaved.com, register and enter you login and password.
STEP 2: Install a Special Software on ARIAG25 to Enable It to Register on WEAVED
Connect your PC to the ARIAG25 (SSH session or serial port)
Login
type your root login/password (root/ariag25)
Download the weaved application
wget https://dl.dropboxusercontent.com/u/83554849/acme_weaved.tar
Uncompress it to /root
tar -xvf acme_weaved.tar
Enter in the directory
cd acme-weaved
Install it
./install
(be shure that your PC is connected to developer.weaved.com now (logged) and that you are in the same NET of ARIAG25)
Step by step
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. debarm:~# wget https://dl.dropboxusercontent.com/u/83554849/acme... --2015-08-24 15:29:25-- https://dl.dropboxusercontent.com/u/83554849/acme...Resolving dl.dropboxusercontent.com... 184.72.249.238, 184.73.231.99, 23.21.210.59, ... Connecting to dl.dropboxusercontent.com|184.72.249.238|:443... connected.
HTTP request sent, awaiting response... 200 OK Length: 194560 (190K) [application/x-tar] Saving to: `acme_weaved.tar' 100%[======================================>] 194,560 361K/s in 0.5s 2015-08-24 15:29:26 (361 KB/s) - `acme_weaved.tar' saved [194560/194560] debarm:~# tar -xvf acme_weaved.tar
acme_weaved/
acme_weaved/weavedWEB
acme_weaved/weaved/
acme_weaved/weaved/web.linux.conf
acme_weaved/weaved/tcp.linux.conf acme_weaved/weaved/ssh.linux.conf acme_weaved/weavedConnectd acme_weaved/install debarm:~# cd acme_weaved debarm:~/acme_weaved# ./install
Usage: /etc/init.d/weavedWEB {start|stop|restart}
Start Weaved service web.linux.conf [OK]
installed and started
STEP 3: Accessing the ARIAG25 Webpage From Your Browser
In developer.weaved.com webpage you will be adviced that there is a new device waiting to register in your weaved account, enable it (confirm the register), give a name (for example ARIAG25_HTTP) to the device and you will see it the current list of devices.
Click on ARIAG25_HTTP and the weaved will connect to ARIAG25 webserver and shows the main webpage. You can access the ARIAG25 from anywhere now!
STEP 4: Accessing the ARIAG25 Webpage From IOS App Too
You should download the weaved on app store or use the web browser.
https://itunes.apple.com/us/app/weaved/id937372469?mt=8
Click on ARIAG25_HTTP device
STEP 5: Share Your ARIAG25
If you don't have the ARIAG25, but want to make a test, please, register now in the developer.weaved.com and send us you weaved ID that we will share my ARIAG25 for you to do tests.
Other weaved services for ARIAG25
We have tested WEBCAM and SSH access to ARIAG25 successfully too.
webcam
ssh
app
STEP 6: Help
If you have some questions about , donĀ“t hesite to take a message for us.
Thank you!
