Introduction: A.D.U Bazooka 1040 (Armor Demolition Unit)
Check my El Diablo Assualt Pistol R-45
This is my Heavy Assault Weapon!
It has a staggering power that will knock you out of your boots!
The range is about 100 ft with the normal bullet.
It has a shoulder support and the very reliable ratchet system.
Don't have any words left so i'll just tell some pros and cons.
Pros:
-Insane power!
-Looks awesome.
-Scares anyone instantly (especially your mom).
-Strong body
-Good range
-Ratchet system
Cons:
-Takes long to build
-Learning to reload is hard
You likey?
Let's get to building then, shall we?
WARNING:
THIS GUN IS LETHAL!!!
NEVER FIRE THIS AT ANYONE!!!
THE BOX PICTURE SHOWS HOW POWERFUL IT IS!!!
ONCE AGAIN, NEVER FIRE THIS AT ANY LIVING THING (Exluding Justin Bieber as he is the son of Satan.)!!!
Titles:
-It passed the 4 star barrier (once).
Pros:
-Insane power!
-Looks awesome.
-Strong body
-Good range
-Ratchet system
Cons:
You likey?
WARNING:
Titles:
Step 1: The Slingshot
This part is just for some extra fun
a little slingshot with reasonable power
The trigger is located on the back of the frame.
Step 2: Sides for Wheels
These parts come in handy, since they make the frame sturdier.
Build this part 2 times
Step 3: Barrel
This part is too let the bullet come out straight of the barrel.
Step 4: Top
This part is for a more sturdy barrel.
If this is not built and not attached to the gun when you try firing, boy are you in serious trouble then
Step 5: Wheels
These are for an easier pullback of the bands and a stronger barrel.
Step 6: Front Barrel
This part is for a more steady shot that goes out straight.
Step 7: Sides
The sides for the barrel.
Step 8: The Rear
This part is for a more sturdy frame.
Step 9: Bars (1)
Strength bars
Step 10: Bars (2)
Strength Bars.
Build this two times.
Step 11: Bars (3)
Strength Bars.
Build this 2 times.
Build this 2 times.
Step 12: Bars (4)
Strength Bars.
Step 13: Scope Thingy
I don't know why i put this on the top, but it just looked cool.
It is not required.
It is not required.
Step 14: The Rubberbands
These are 5 royal postal rubberbands tied together.
Make 2 of them.
Make 2 of them.
Step 15: The Top of the Rear
This part is for more strength.
Step 16: Bullet
This is the original bullet designed purely for destruction.
Step 17: Strength Bars
This one is for a sturdy frame.
Step 18: Shoulder Rest
This part is too have a steady base when you are carrying it around.
Step 19: Trigger and Handle
This part is too hold back the rubberbands, and too have a firm grip onto the gun.
Step 20: Bi-Pod
This is not an actual bi-pod, but it gives some support when you put it down.
Step 21: Assembly (1)
The pictures speak for themselves.
If you have a question, post you're problem on my orangeboard.
(I made the assembly in several steps because, the computer would stop when i wanted to upload all at once)
Barrel
Barrel
Step 22: Assembly (2)
Rear + Barrel
Rear + Barrel
Step 23: Assembly (accesories)
An accesorie for a steady shot (bi-pod), or when you put it down it has a steady base.
Cannon Completed:
Vie step 24 for loading.
Cannon Completed:
Step 24: (Re)loading
This is pretty hard and will require some skills
and a bit of training won't harm you either
Cannon:
-Pull back the rubberbands (you can get a grip at the blue rod squares)
-Get the bullet
-Slide it down the barrel
-FIRE!!!
Small Slingshot:
-Get the bullet
-Slide in the yellow rod
-FIRE!!!
Cannon:
-Get the bullet
-FIRE!!!
Small Slingshot:
-Get the bullet
-FIRE!!!
Step 25: You're Done!!!
Well you've built yourself one of the biggest guns on Instructables:
The A.D.U Bazooka 1040
Have freaking much fun!!!
