Introduction: AI Generated Lithopane Lamp
In this instructable, you will learn how to create a stunning lithophane lamp featuring AI-generated paintings, beautifully illuminated by an RGB LED strip.
Whether you’re looking to enhance your home decor, create a unique gift, or simply explore the possibilities of modern technology, this lithophane lamp project is a fantastic way to get hands-on with 3D printing, electronics, and AI art!
There are a few things you will require:
- 3D Printer: To print the lithophane lamp.
- Translucent Filament: White PLA or PETG filament works well.
- RGB LED Strip: One with a remote control or Bluetooth.
- Glue Gun: To glue the lithopane lamp together.
- Internet Access: To generate the AI images and lithopane
Step 1: Generate Images
To begin creating AI Art, you can use Bing's DALL-E:
Go to the Bing Image Creator powered by DALL-E.
Sign in with your Microsoft account if required.
Input prompts to generate unique artwork. Experiment with different descriptions to get a variety of results.
Once you are satisfied with the generated images, download four images of your choosing in high resolution!
Step 2: Convert Images to Lithopane
Convert to Lithophane:
- First, head over to LithophaneMaker and upload your four images to the site.
- Then, change the Depth, Width and Height to 150mm.
- Afterward, change the Light Bulb Diameter and Socket Outer Diameter to 70mm each.
- Then, crop the image to your liking and press on Create .stl
Step 3: Printing
Print the Lithophane Panels and Lamp Frame
- 3D Print Lithophanes: Use your white filament to print your lithophane box.
- 3D Lamp Frame: Then, download the attached files and print both the cover and lamp base.
You may need to use supports for the Lithopane Lamp.stl.
Step 4: Assemble the Lamp
Now that you've finished printing, it's time to assemble the lamp.
- Install RGB LED Strip: Begin by wrapping your RGB strip around the centre pole, using the adhesive on the back to secure it in place.
- Connect controller: Afterwards, connect your RGB controller and secure it in place using some Hot Glue.
- Gluing Base: Then, thread the main pole through the hole at the bottom of the Lithopane Lamp and then use some hot glue to secure the lamp box in place.
- Cable Cover: Finally, slide the cable through the cutout in the Lithopane Lamp Clip and then press it firmly into the back of the lithopane to secure it in place!
Step 5: Finished
Finally, plug in your Lithopane Lamp and it should be complete!
By using Bing's DALL-E to generate personalized images and converting them into lithophanes, you have transformed digital art into an illuminated masterpiece.
I hope this Instructables has inspired you and provided a rewarding experience!
