Introduction: How to Make Lamp From Toy Gun and Ikea
Hello friends!
I decided to make a birthday gift for my friend. As you know, all men's are children at heart. The boy was 35 years old, he is fond of strikeball, and I decided that the table lamp in the form of an AK-47, will be a perfect gift for him.
Step 1:
To make the lamp I will needed:
- Toy gun
- Lampshade
- Lamp base
- RGB light bulb
- Soil and spray paint
- Aluminium tube
The lampshade and base for the lamp I ordered from Ikea. Toy gun I bought at the toy store.
Step 2:
First thing I did was disassemble the gun and throw out all unnecessary. I left only reload mechanism and the trigger.
Step 3:
Base tube diameter 12 mm. It's too thick for the muzzle, so I made an adapter. Used an 8 mm diameter aluminum tube.
Step 4:
In order for the 8mm tube to enter the barrel, it had to be squandered.
Step 5:
Next I made a hole for the base tube.
Step 6:
Also made a hole in the decorative cover.
Step 7:
Further I decided to to remove traces from casting plastic. I took sandpaper and cleaned up the tracks.
Step 8:
Before applying the primer, I took a fine sandpaper and processed all the parts of the machine.
Step 9:
All dedusted and degreased. I start painting. The soil was applied in 2 layers.
The first layer.
Step 10:
Second layer.
Step 11:
In the white version, the machine looks great. But after drying the soil, on the" wooden " parts of the machine, the paint began to turn yellow.
Step 12:
Paint was applied in 3 layers. Each layer was dried for at least an hour.
Step 13:
After painting waited 2 days before proceeding to the final Assembly.
Step 14:
While the paint dried, I began to assemble a rack for the machinegun. Cut off the bulb base and the wire.
Step 15:
Took an aluminum tube on 8 mm, inserted into the bulb base and filled with superglue.
Step 16:
To fix this tube, I wound some duct tape. I put it in a black tube and Superglued it
Step 17:
Proceed to the final Assembly. I fix the tubes with the help of thermal glue.
Step 18:
The horn of the machine gun also fixed on the hot melt glue.
Step 19:
I will will use led bulb with RGB backlight and Bluetooth speaker. The brightness of the lamp is controlled by the remote control. You can turn on the multi-colored backlight, turn on the music through the Bluetooth speaker. The volume of the speaker is enough for a room with an area of 15m.
Step 20:
Here is such spectacular lamp I have made. The lamp perfectly fit into the interior of my friend's apartment. By the way, he was pleasantly surprised by my gift!
Step 21:
Hope you liked my lamp! Try to create your own lamp.
See you soon!
