Introduction: ANIMATED INDIAN FLAG USING BLENDER
Blender tutorial showing you to how to use the cloth simulator to make an animated flag.
Step 1: ADD IMAGE AS PLANE
- PRESS A TO SELECT ALL.
- PRESS X TO DELETE EVERYTHING INCLUDING LAMP , CAMERA AND CUBE
- PRESS SHIFT+A THEN ADD MESH THEN ADD IMAGE AS PLANE
- THEN SELECT ANY FLAG PICTURE FROM YOUR COMPUTER
- I USED INDIA FLAG
- THEN PRESS R THEN X THEN 90 TO ROTATE ALONG X AXIS
Step 2: SUBDIVIDE YOUR PLANE
- PRESS TAB FOR EDIT MODE
- PRESS CTRL +R FOR LOOP CUT
THEN PRESS W AND CHOOSE SUBDIVIDE
PRESS T TO SHOW THE LEFT HAND SIDE TOOLBAR
CHANGE THE NUMBERS OF LOOP CUTS TO 10
HIT ENTER
AND AGAIN PRESS W AND SELECT SUBDIVIDE
Step 3: PINNING
- GO TO PHYSICS OPTION IN THE PROPERTIES PANNEL
- SELECT CLOTH
- UNDER THE CLOTH SECTION TURN ON PINNING
- THEN GO TO OBJECT DATA BUTTON IN THE PROPERTIES PANNEL
- MAKE SURE YOU ARE IN EDIT MODE
- SELECT THE ALL LEFT VERTEX OF THE PLANE FOR PINNING
- TO SELECT ALL THE LEFT SIDE VERTEX HOLD ALT AND SELECT THE LEFTMOST VERTEX THIS WILL SELECT ALL THE VERTEX
- CLICK ON + BUTTON UNDER VERTEX GROUP
- DOUBLE CLICK TO RENAME 'PIN'
- AND CLICK ON ASSIGN BUTTON
- NOW GO BACK TO PHYSICS IN THE PROPERTIES PANNEL
- SELECT THE PIN VERTEX GROUP FOR PINNING
- SELECT SELF COLLISION
- SELCT DYNAMIC MESH
Step 4: FORCE FIELD-WIND
- PRSS SHIFT+ A TO ADD FORCE FIELD AND SELECT WIND
- SET THE STRENGTH VALUE TO 1000
- ALIGN THE FORCE FEILD AS SHOWN IN THE PICTURE
Step 5: CLOTH SETTINGS
- IN THE PROPERTIES PANNEL GO TO PHYSICS
- UNDER THE CLOTH SECTION SET THE FOLLOWING VALUES
- MASS-0.05
- STRUCTURE-1
- AIR-0.3
- STEPS-7
- BENDING-0.050
- SPRING-0.1
- VELOCITY-1
- GRAVITY-0.7
Step 6: SMOOTH AND MODIFIER
- SELECT THE PLANE AND UNDER TOOLBAR OPTION SELECT SMOOTH
- SELECT MODIFIERS AND ADD MODIFIER SUBDIVISION MODIFIERS
- SET VIEW AND RENDER VALUE TO 2
Step 7: DYNAMIC SKY FOR BACKGROUD
- GO TO FILES AND THEN USERS PREFERENCES
- UNDER ADDON SEARCH DYNAMIC
- SELECT BOTH THE ADDONS
- AND THEN SAVE USERS SETTINGS
- THEN CLICK ON CREATE BUTTON
Step 8: FINAL STEP
- NOW SETUP YOUR CAMERA BY ADDING A CAMERA
- SHIFT+A TO ADD A CAMERA
- PRESS 0 FOR CAMERA MODE
- ALIGN YOUR CAMERA AS YOU WANT
- FOR VIDEO REFERENCE GO TO MY YOUTUBE CHANNEL
- SUBSCRIBE MY YOUTUBE CHANNEL FOR MORE ANIMATION VIDEOS AND TUTORIALS.............
