ANT-PROOF PET FOOD BOWL
Intro: ANT-PROOF PET FOOD BOWL
My cat loves tuna. So do the ants. The solution to the ant problem is to put a water moat around the cat food bowl.
Starting with the stainless steel bowl for the tuna, I found that it fits perfectly inside the plastic container that CDs come in. For the feeding bowl you use, you may need to find a different container it will fit into. That container, in turn, needs to fit inside another plastic container. Leave an adequate distance between them for the water moat. The moat has to be wide enough that an ant can not reach across it without swimming, which they tend not to do.
STEP 1:
A few dabs of epoxy glues the center container to the base of the outer container. It will stay centered and not float around when the gap between them is filled with water. That is all there is to it. It is a very simple thing to make once you find the right size containers to make it with.
15 Comments
ClintD 9 years ago
This works but the only issue is down south the water will evaporate quickly during the summer. I ended up getting the mote from http://www.antproofbowl.com.
GrumpyOldGoat 5 years ago
A little vegetable oil will help with the evaporation.
A drop of dish detergent will let the ants sink if they try it.
asteude 12 years ago
Thinkenstein 12 years ago
jmccleve 12 years ago
VampiricPie 13 years ago
KDiggins 13 years ago
bben46 13 years ago
jody250 13 years ago
GeekTinker 13 years ago
supertav 14 years ago
Thinkenstein 14 years ago
pmpinc 14 years ago
cbennett811 14 years ago
