Introduction: ARDUINO - MOTOR BRUSHLESS With ESC
I want to show you in this "Instructable" how to control a brushless motor with Arduino.
Step 1: Parts Required
1.- Arduino UNO
2.- Battery and Compact Charger
3.- ESC
4.- BrushLess Motor
5.- Battery and Motor/ESC connectors
5.- Breadboard
6.- Wire
7.- PC with Arduino IDE
I bought some components by Internet:
1.- BrushLess Motor/ESC/Propeller/connectors set:
http://www.banggood.com/XXD-2212-MotorZTW-AL30A-Br...
2.- Battery
http://www.banggood.com/Wholesale-Lion-Power-11_1....
3.- Compact Charger
http://www.banggood.com/TITAN-B3-2-3Cell-7_4v-11_...
Step 2: Battery Charge
We need to charge de battery, then connect the charger to the power and 3 green LED lights will illuminate. Then connect the battery to the charger and 3 red LED lights will illuminate. When the 3 battery cells are 100% the 3 green LED lights will illuminate.
Step 3: Soldering Connectors
We need to solder some components:
1.- BrushLess Motor
2.- ESC
Step 4: Upload Arduino Program Control
We need to load the program that controls the ESC/Motor
- Code:
/*Coded by Marjan Olesch
Sketch from Insctructables.com Open source - do what you want with this code!
#include <servo.h>
int value = 0; // set values you need to zero
Servo firstESC, secondESC;
//Create as much as Servoobject you want.
//You can controll 2 or more Servos at the same time
void setup() {
firstESC.attach(9); // attached to pin 9 I just do this with 1 Servo
Serial.begin(9600); // start serial at 9600 baud
void loop() {
//First connect your ESC WITHOUT Arming. Then Open Serial and follo Instructions
firstESC.writeMicroseconds(value);
if(Serial.available())
value = Serial.parseInt(); // Parse an Integer from Serial
}Step 5: Create Sketch
Once uploaded to the Arduino sketch by the USB wire then we connect motor brushless with the ESC. And we connect the ESC to the Arduino like:
- ESC Green wire -> GND Arduino
- ESC Red wire -> Null (dont connect because its possible that the usb port PC will crash)
- ESC Yelow wire -> PIN 9 Arduino
Open the monitor serial at Arduino IDE and write 700 ( it's the minimum value for the motor)
Connect the battery to the ESC
And it will sound some melody from the ESC.
You can write at serial monitor diferent values like ( 750,800,900,..., maximum value is 1900 for this motor)
