Introduction: AT89S52 - Veroboard & Upcycling Components
Build your own ancestor of Arduino with upcycled components.
32 I/O programmable. Is this an ISP programmable microcontroller.
Easy and instructive build project.
(Ok... i buy Veroboard for this one, or you could do it on breadboard)
Step 1: Find Components
- 2 x 22 pF Ceramic capacitors
- 2 x 180 ohm Resistor 1/4W
- 1 x 10k ohm Resistor 1/4W
- 2 capacitor 10uF (could put 10uF or 1uF for reset)
- 1 capacitor 1uF
- 1 x 20 MHz Oscillator 2 points
- 1 x LM7805 Regulator 5V
- 1 x Interruptor 2 positions
- 1 x USB B female connector
- 4 x 8 pins male headers
- 2 x 4 pins male headers
- 1 x AT89S52 Microcontroller
- 1 x Veroboard
- 2 x Leds 3mm (1 red and 1 green) for check supply
Required: Stuff for soldering.
Note, all components was upcycled. You could find them on electronic waste.
I've just buy Veroboard.
Step 2: Soldering
Follow previous schematic for soldering components on Veroboard.
Warning: Try on breadboard before solder.
Step 3: Checking
Check power supply with Leds.
Put the microcontroller in good position. Point on corner of AT89S52 is first pin.
It's an Arduino looks like with old stuff.
Step 4: Upload Your Program
Now it's time for programming microcontroller. Choose your method, and try a Blink code for testing it.
I'm using a professionnal ISP programmer with ZIF socket for upload hex file. You could program it with an Arduino Uno and using goods pins.
Upcycle for fun.
