Introduction: ATtiny85 - Bluetooth
In the last instructable I showed you how to program an ATiny85, in this instructable I will show you how to start serial communication with the ATiny85 over a Bluetooth network. For this instructable I will be using a HC05 Bluetooth module which can be purchased for cheap on eBay.
So lets get started....
Step 1: Tools and Components
Here is what you need -
- Attiny84 or 85
- Bluetooth module
- A bread board
- Jumper wires
Step 2: Circuit
Setup the connections between the ATiny and the Bluetooth as follows -
- Bluetooth Module Rx --> ATiny85 Pin 1
- Bluetooth Module Tx --> ATiny85 Pin 2
- Bluetooth Module Gnd --> ATiny85 Pin 4
- Bluetooth Module VCC --> ATiny85 Pin 8
Step 3: Code
Here is a test sketch you can run, connect a led at 6 and upload the code. Sending 1 from a serial terminal will turn on the LED and sending 0 will turn it off.
#include //Software Serial Port
#define RxD 1 #define TxD 2#define DEBUG_ENABLED 1 SoftwareSerial blueToothSerial(RxD,TxD);
int led = 4; void setup() { pinMode(RxD, INPUT); pinMode(TxD, OUTPUT); setupBlueToothConnection(); pinMode(led,OUTPUT); digitalWrite(led,HIGH); } void loop() { char recvChar; while(1){ //check if there's any data sent from the remote bluetooth shield if(blueToothSerial.available()){ recvChar = blueToothSerial.read(); if(recvChar == '1') digitalWrite(led,HIGH); else digitalWrite(led,LOW); } } } void setupBlueToothConnection() { blueToothSerial.begin(9600); //Set BluetoothBee BaudRate to default baud rate 38400 blueToothSerial.print("\r\n+STWMOD=0\r\n"); //set the bluetooth work in slave mode blueToothSerial.print("\r\n+STNA=HC-05\r\n"); //set the bluetooth name as "HC-05" blueToothSerial.print("\r\n+STOAUT=1\r\n"); // Permit Paired device to connect me blueToothSerial.print("\r\n+STAUTO=0\r\n"); // Auto-connection should be forbidden here delay(2000); // This delay is required. //blueToothSerial.print("\r\n+INQ=1\r\n"); //make the slave bluetooth inquirable blueToothSerial.print("bluetooth connected!\n"); delay(2000); // This delay is required. blueToothSerial.flush(); }
