Introduction: AXE Can Safe
A easy to make can safe that easily allows you to hide stuff.
Step 1: Materials:
You will only need three materials
- An Empty Can of AXE
- A Razor Blade
- Something to Hide
- A Razor Blade
- Something to Hide
Step 2: Getting Started
Carefully pull off the top part of the AXE can with your hand and set it aside for now.
Step 3: Get Inside That Can
You need to use the blade of the razor to carefully pry the silver cap up around the edges so that you can push the whole cap inside of the can. Once that is done you need to reach inside with your hand(or Pliers) and pull the silver cap out from the top.
Step 4: Store Things Inside of Your Safe Can
You can now put what ever you can fit into your can for safe storage, such as Money, passwords, notes, ETC.
Step 5: Cover It Back Up
Take the cap to the Spray bottle that you set aside earlier and genitally press it back onto the can so that what ever is inside the can is not visible.
